The Privacy Screen for Dell P3424WE from StarTech.com offers effective privacy protection while ensuring clarity in display viewing. With its microlouver privacy technology, this filter provides 2-way privacy, making it ideal for both personal and professional environments. Additionally, it features a dual surface finish of glossy and matte, allowing users to choose their preferred viewing experience. The fingerprint-resistant coating keeps the screen clear of smudges, while the removable design allows for easy installation and maintenance. Compatible with ultra-wide 34-inch screens, this display privacy filter includes adhesive strips, slide mount tabs, and a wiping cloth for convenient setup and upkeep. Moreover, it reduces blue light by 51% and allows 65% light transmittance, enhancing user comfort during longer viewing sessions.
Effective privacy protection
This display privacy filter utilizes microlouver technology to create a barrier against unauthorized viewing from both sides, ensuring sensitive information remains confidential. -
Versatile compatibility
Designed specifically for ultra-wide 34-inch screens, this privacy filter accommodates curved displays, making it suitable for a variety of setups. -
Durable and user-friendly
The scratch-resistant surface and fingerprint-resistant coating offer durability, while the removable design allows for quick application and removal. -
Enhanced visual comfort
With a reduction of 51% in blue light and a light transmittance of 65%, this filter maintains image clarity while contributing to reduced eye strain during extended use. -
Complete installation kit
The package includes all necessary components such as adhesive strips, slide mount tabs, and a wiping cloth, ensuring a hassle-free setup experience.
- StarTech.com Privacy Screen For Dell P3424WE, Double-Sided Filter, TAA - display privacy filter - 34" (ultra-wide) - TAA Compliant
- Product Type
- Display privacy filter - 2-way
- Installation Type
- Removable - plug-in/adhesive
- Package Content
- Adhesive strips, slide mount tabs, wiping cloth
- Black
- Display Screen Size Compatibility
- 34" (ultra-wide)
- 81.2 cm x 34.4 cm
- 700 g
- TAA Compliant
- 2-year warranty
- Product Type
- Package Content
- 34" (ultra-wide)
- 81.2 cm - 34.4 cm
- 700 g
- Shipping Dimensions (WxDxH) / Weight
- 87.5 cm x 47.3 cm x 0.5 cm / 700 g
- Black
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Aspect Ratio
- 21:9
- Surface Finish
- Glossy/matte
- Scratch Resistant
- Mounting Kit
- Included
- Horizontal orientation, compatible with curved screen, microlouver privacy technology, +/- 30° visible angle, 51% blue light reduction, 65% light transmittance, fingerprint-resistant coating
- TAA Compliant
- Limited warranty - 2 years
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.33 |
StarTech.com Privacy Screen Dell U3824DW | In Stock | £147.94 |
