Experience audiovisual clarity and immersive sound with the StarTech.com 1.5m (4.9ft) Premium High Speed HDMI Cable with Ethernet, 4K. Designed for durability and performance, this cable features a 10000 bend lifespan, aramid fiber core, and gold-plated connectors, ensuring it stands up to the rigors of frequent use while maintaining a high-quality connection. With support for 4K60Hz resolution, HDR, and up to 32 audio channels, it delivers a superior viewing experience, perfect for enjoying movies, games, and more in stunning detail and depth. Its compatibility with HDCP 2.2 and a wide range of devices makes it a versatile choice for any setup, from home entertainment systems to professional presentations. Elevate your audiovisual experience with this HDMI cable, designed to bring your content to life with vivid colors, sharp images, and rich sound.
Enhanced durability
Boasting a 10000 bend lifespan and a robust aramid fiber core, this HDMI cable is designed to withstand frequent bending and adjustments. Its tear-resistant and wear-resistant features ensure long-term reliability for all your AV needs. -
Superior audiovisual experience
Supports 4K60Hz resolution and HDR, providing a stunning visual experience with vibrant colors and deeper contrasts. With up to 32 audio channels and support for 7.1 channel surround sound, it delivers immersive audio that complements the high-definition video quality. -
High compatibility
Featuring gold-plated connectors and support for HDCP 2.2, this cable is compatible with a wide range of devices including PCs, TVs, monitors, laptops, and projectors. Its versatility makes it an ideal choice for various setups, from home theaters to professional presentations. -
Advanced features
Equipped with EMI protection to minimize interference, and supporting advanced audio formats like Dolby Atmos and Dolby TrueHD. It also features HDMI CEC support for integrated control and ARC for simplified connectivity, enhancing your multimedia setup with ease and efficiency.
- StarTech.com 1.5m (4.9ft) Premium High Speed HDMI Cable with Ethernet, 4K - HDMI cable with Ethernet - 1.5 m
- Cable
- Premium High Speed - HDMI cable with Ethernet
- Technology
- Shielded
- Length
- 1.5 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Passive cable, 4K60Hz (4096 x 2160) support, rugged, HDR support
- Limited lifetime warranty
- Cable Type
- Premium High Speed - HDMI cable with Ethernet passive, 4K60Hz (4096 x 2160) support, rugged, HDR support
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1.5 m
- Plated Connector
- Gold
- Recommended Use
- Projector, monitor, TV, PC, laptop, display
- Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), Dolby TrueHD support, Dolby Digital Plus, Dolby Atmos support, support HDR10, strain relief, 32 audio channels, aramid fibre core, tear-resistant, outer diameter 4.5mm, wear resistant, 1536 kHz audio sampling rate, 7.1 channel Surround Sound, 5.1 channel surround sound, bandwidth of 18 Gbps, EMI protection, BT.2020 support, 10000 bend lifespan, 5000 insertions lifespan
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS, WEEE, HDCP 2.2
- 38 g
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 2.5 cm
- Shipping Weight
- 40 g
- Limited warranty - lifetime
