StarTech.com Premium digital audio cable (optical) - SPDIF - 6.1 m-TOS Link
Quicklinx: 3ZJMWS00 Mfr#: TOSLINK20
Type: Audio
Length: 6.1m
Stock Status: In Stock, Used Stock
Select:
2 in stock
£19.42 ex VAT
£23.30 inc VAT
Standard delivery Delivered within 3-5 working days
Deliver high quality optical digital sound, with no signal interference. The TOSLINK20 20ft Toslink Optical Digital Audio Cable provides clean, accurate sound, with no distortion or signal interference, offering a high quality connection between your PC audio card and stereo/home theater system.
The TOSLINK20 is constructed for maximum durability, for dependable, long-lasting connections.
StarTech.com 20 ft. (6.1 m) Digital Optical Audio Cable - Toslink Digital Optical SPDIF - Premium - Male/Male - Optical Audio Cable (TOSLINK20) - digital audio cable (optical) - SPDIF - 6.1 m
Cable
Digital audio cable (optical) - SPDIF
Fibre optic
Length
6.1 m
Connector
TOSLINK - male
Connector (Second End)
TOSLINK - male
P/N: FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, PEXSOUND7CH, STNDMTV70
Cable Type
Interface Supported
SPDIF
Fibre optic
Jacket Material
PVC
Length
6.1 m
Connector
TOSLINK - male
TOSLINK - male
Limited warranty - lifetime
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 3ZJM 042952
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £11.11
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Audio
Length: 6.1m
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
