StarTech.com Premium Certified HDMI Cable
Quicklinx: J9X4WS00 Mfr#: HDMI2-CABLE-4K60-10W
Hurry, only 1 left in stock!
£6.55 ex VAT
£7.86 inc VAT
Connect to a 4K UHD TV or monitor, using this Premium Certified HDMI 2.0 Cable. The connector markings enable quick visual identification, distinguishing this cable from other similar-looking or unmarked HDMI cables. Eliminate guesswork and always choose the appropriate cable to support full HDMI 2.0 with Ethernet capabilities. For seamless operation between HDMI-enabled devices, the Premium HDMI Cable is Certified for guaranteed HDMI 2.0 performance and backward compatibility. Certified cables provide consistent, reliable performance across multiple resolutions and refresh rates. This High Speed HDMI Cable features a flexible TPE outer jacket that is tested to withstand 2,000 bending cycles at -/+60 degrees, and routes easily around corners and desk edges. Robust strain reliefs enable convenient positioning of the cable. The durable Gold-plated connectors are rated to operate beyond 10,000 insertions. This Certified HDMI Cable supports full HDMI 2.0 features, including resolutions up to 4K 60Hz using a compatible HDMI source and display, high refresh rates including 1440p 144Hz and 1080p 240Hz, 21:9 Aspect Ratio, High Dynamic Range (HDR10) for higher contrast ratio, High-Bandwidth Digital Content Protection (HDCP) 2.2 for a secure connection between source and display, Audio Return Channel (ARC), Up to 32 Uncompressed Digital Audio Channels, HDMI Ethernet Channel (HEC) for network connectivity over HDMI, and backward compatible with previous HDMI versions. This HDMI 2.0 Cable is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
StarTech.com 10ft (3m) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 3 m
Cable
Premium High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
30
Length
3 m
White
Connector
HDMI - male
Connector (Second End)
HDMI - male
Passive cable, 4K60Hz UHD support, 2K144Hz support, HDR10 support
Cable Type
Premium High Speed - HDMI cable with Ethernet passive, 4K60Hz UHD support, 2K144Hz support, HDR10 support
Shielded
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
3 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), 4k(2160p)@60Hz / 1440p@144Hz / 1080p@240Hz, 32 audio channels, 10000 insertions lifespan, 2000 bend lifespan, outer diameter 6mm, marked connectors, strain relief, halogen free, EMI protection, 21:9 cinema aspect ratio
White
Connector
19 pin HDMI Type A - male
HDCP 2.2, RoHS, WEEE
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
3 cm
Shipping Weight
140 g
Limited warranty - lifetime
