The 7m Premium Certified High Speed HDMI Cable by StarTech.com is designed to provide reliable, high-quality connections for all your AV equipment. With support for 4K resolution at 60 Hz, this cable ensures stunning visuals for any setup. It features an HDMI Ethernet Channel, Audio Return Channel, and compatibility with HDR10, allowing an enriched entertainment experience. Built to last, the cable has a lifespan of 10,000 insertions, making it a durable choice for frequent use.
Constructed with gold-plated connectors and advanced shielding made of aluminum mylar foil with a braid, this HDMI cable minimizes interference and ensures a clean signal. The flexible thermoplastic elastomer jacket allows for ease of installation while providing durability. Fully compliant with RoHS and Halogen-free standards, this HDMI cable meets high performance demands and adheres to environmental regulations, making it a responsible choice for consumers.
Durable construction
The cable is built to endure with a lifespan of 10,000 insertions, ensuring long-term performance. -
High-speed performance
With an 18 Gbps data rate, this HDMI cable delivers rapid and reliable data transmission for high-definition video and audio. -
Advanced shielding
Designed with aluminum mylar foil and braid, this cable provides effective EMI protection, reducing interference for a cleaner signal. -
Versatile compatibility
Supports HDMI CEC, enabling control over connected devices from a single remote for user-friendly operation. -
Flexible jacket material
The thermoplastic elastomer construction offers flexibility for easy installation while maintaining durability against wear and tear.
- StarTech.com 7m (22.9ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 7 m
- Cable
- Premium High Speed - HDMI cable with Ethernet
- American Wire Gauge (AWG)
- 24
- Length
- 7 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K60Hz support, passive cable
- Limited lifetime warranty
- Cable Type
- Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
- 24
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 7 m
- Plated Connector
- Gold
- 18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), HDR 10 support, EMI protection, 10000 insertions lifespan, strain relief, outer diameter 9 mm
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS, HDCP 2.2, halogen-free
- 500 g
- Shipping Width
- 33 cm
- Shipping Depth
- 25.2 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 500 g
- Limited warranty - lifetime
