StarTech.com Premium Certified HDMI Cable 7m
Quicklinx: J1LKWS00 Mfr#: HDMI2-CABLE-4K60-7M
£17.11 ex VAT
£20.53 inc VAT
The 7m Premium Certified High Speed HDMI Cable by StarTech.com is designed to provide reliable, high-quality connections for all your AV equipment. With support for 4K resolution at 60 Hz, this cable ensures stunning visuals for any setup. It features an HDMI Ethernet Channel, Audio Return Channel, and compatibility with HDR10, allowing an enriched entertainment experience. Built to last, the cable has a lifespan of 10,000 insertions, making it a durable choice for frequent use.
Constructed with gold-plated connectors and advanced shielding made of aluminum mylar foil with a braid, this HDMI cable minimizes interference and ensures a clean signal. The flexible thermoplastic elastomer jacket allows for ease of installation while providing durability. Fully compliant with RoHS and Halogen-free standards, this HDMI cable meets high performance demands and adheres to environmental regulations, making it a responsible choice for consumers.
  • Durable construction
    The cable is built to endure with a lifespan of 10,000 insertions, ensuring long-term performance.
  • High-speed performance
    With an 18 Gbps data rate, this HDMI cable delivers rapid and reliable data transmission for high-definition video and audio.
  • Advanced shielding
    Designed with aluminum mylar foil and braid, this cable provides effective EMI protection, reducing interference for a cleaner signal.
  • Versatile compatibility
    Supports HDMI CEC, enabling control over connected devices from a single remote for user-friendly operation.
  • Flexible jacket material
    The thermoplastic elastomer construction offers flexibility for easy installation while maintaining durability against wear and tear.
StarTech.com 7m (22.9ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 7 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
24
Length
7 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
24
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
7 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), HDR 10 support, EMI protection, 10000 insertions lifespan, strain relief, outer diameter 9 mm
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.2, halogen-free
500 g
Shipping Width
33 cm
Shipping Depth
25.2 cm
Shipping Height
2 cm
Shipping Weight
500 g
Limited warranty - lifetime
