StarTech.com Premium Certified HDMI Cable 5m
Quicklinx: J1LJWS00 Mfr#: HDMI2-CABLE-4K60-5M
25 In Stock
£10.58 ex VAT
£12.69 inc VAT
Experience dependable performance with the 5m Premium Certified High Speed HDMI Cable from StarTech.com. Featuring robust aluminum mylar foil and braid shielding material, this cable ensures minimal interference for high-resolution audio and video. It supports 4K60Hz content at an 18 Gbps data rate, allowing users to enjoy sharp images and clear sound. The inclusion of an HDMI Ethernet Channel adds convenience, making it suitable for streaming or gaming setups with multiple devices.
Designed for longevity, this cable boasts features like strain relief and a lifespan of 10,000 insertions. The gold-plated connectors enhance signal integrity, ensuring a stable connection. With compliance to RoHS and HDCP 2.2 standards, this HDMI cable meets modern viewing requirements while remaining environmentally friendly. Choose the StarTech.com 5m Premium Certified High Speed HDMI Cable for a durable and efficient solution for all your HDMI needs.
  • Sturdy design
    The cable features strain relief and an outer diameter of 8.5 mm, ensuring durability during use and protection against wear.
  • High performance
    It supports an 18 Gbps data rate, providing high-quality audio and video transmission for a seamless viewing experience.
  • Advanced compatibility
    Equipped with HDMI Ethernet Channel and support for Audio Return Channel, this cable easily integrates with a variety of devices.
  • Environmentally compliant
    The cable meets RoHS and halogen-free standards, making it a safe choice for users and the environment.
StarTech.com 5m (16.4ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 5 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
26
Length
5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
26
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
5 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), HDR 10 support, EMI protection, 10000 insertions lifespan, strain relief, outer diameter 8.5mm
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.2, halogen-free
358 g
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
363 g
Limited warranty - lifetime
