StarTech.com Premium Certified HDMI Cable 50cm
Quicklinx: J1K6WS00 Mfr#: HDMI2-CABLE-4K60-50C
32 In Stock
£4.71 ex VAT
£5.65 inc VAT
The 1.6ft (50cm) Premium Certified High Speed HDMI Cable from StarTech.com delivers a viewing experience with 4K at 60Hz support. Designed with durability in mind, this cable features high-quality aluminum mylar foil shielding with a braid to minimize interference. The gold-plated connectors ensure signal integrity, enhancing audio and video performance for higher resolutions. Additionally, the cable supports up to 32 audio channels, providing a sound experience for an immersive home theater setup.
With an 18 Gbps data rate, this HDMI cable seamlessly transmits data for video and audio. It incorporates features such as HDR 10 support, HDMI Ethernet Channel, and Audio Return Channel for added functionality. The cable's thermoplastic elastomer (TPE) jacket provides flexibility and durability while maintaining a sleek profile, and strain relief design adds longevity to the cable. Whether connecting devices for gaming, streaming, or presentations, this HDMI cable is an accessory for achieving high-performance connectivity.
  • High-quality shielding
    Constructed with aluminum mylar foil and braid, this cable minimizes electromagnetic interference, maintaining signal strength and integrity.
  • Flexible and durable jacket
    The thermoplastic elastomer (TPE) material ensures the cable remains robust while providing the flexibility needed for easy installation.
  • Advanced audio capabilities
    Supports up to 32 audio channels, allowing for a sound experience whether streaming movies, gaming, or listening to music.
  • Compliant with standards
    Meets RoHS and halogen-free standards, making it an environmentally responsible choice for connectivity needs.
  • Passive cable design
    Utilizes a passive construction, allowing for ease of use without the need for additional power, ensuring straightforward connectivity.
StarTech.com 1.6ft (50cm) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 50 cm
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
30
Length
50 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
50 cm
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDR 10 support, 32 audio channels, cable diameter 6 mm, strain relief, EMI protection
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.2, halogen-free
Limited warranty - lifetime
