StarTech.com Premium Certified HDMI Cable 4m
Quicklinx: J1LHWS00 Mfr#: HDMI2-CABLE-4K60-4M
£9.65 ex VAT
£11.58 inc VAT
Enhance audio and video connectivity with the 4m (13ft) Premium Certified High Speed HDMI Cable from StarTech.com. This cable supports 4K 60 Hz video quality, making it ideal for high-definition displays. With a data transfer rate of 18 Gbps and advanced technology features such as HDMI Ethernet Channel, Audio Return Channel, and HDR 10 support, this cable ensures a seamless and immersive viewing experience.
Constructed with durable materials, the cable includes gold-plated connectors and aluminum mylar foil shielding with braid, offering excellent EMI protection and a lifespan of up to 10,000 insertions. Designed for flexibility and longevity, it features strain relief and a thermoplastic elastomer jacket, making it a reliable choice for any AV setup.
  • High-Quality Construction
    The cable features gold-plated connectors and aluminum mylar foil shielding, effectively minimizing interference and ensuring a dependable connection for high-resolution audio and video.
  • Versatile Compatibility
    This HDMI cable supports multiple advanced technologies, including HDMI CEC support, allowing users to control compatible devices with one remote, enhancing convenience in any entertainment setup.
  • Robust Performance
    With support for HDR 10 and a data rate of 18 Gbps, this cable delivers an exceptional viewing experience, suitable for 4K content and gaming applications.
  • Long-Lasting Durability
    Designed with a lifespan of 10,000 insertions, the cable features a strain relief design and a thermoplastic elastomer jacket, ensuring it withstands regular use while maintaining performance.
StarTech.com 4m (13ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 4 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
28
Length
4 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
28
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
4 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), HDR 10 support, EMI protection, 10000 insertions lifespan, strain relief, outer diameter 7.3mm
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.2, halogen-free
287 g
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
291 g
Limited warranty - lifetime
