Enhance audio and video connectivity with the 4m (13ft) Premium Certified High Speed HDMI Cable from StarTech.com. This cable supports 4K 60 Hz video quality, making it ideal for high-definition displays. With a data transfer rate of 18 Gbps and advanced technology features such as HDMI Ethernet Channel, Audio Return Channel, and HDR 10 support, this cable ensures a seamless and immersive viewing experience.
Constructed with durable materials, the cable includes gold-plated connectors and aluminum mylar foil shielding with braid, offering excellent EMI protection and a lifespan of up to 10,000 insertions. Designed for flexibility and longevity, it features strain relief and a thermoplastic elastomer jacket, making it a reliable choice for any AV setup.
High-Quality Construction
The cable features gold-plated connectors and aluminum mylar foil shielding, effectively minimizing interference and ensuring a dependable connection for high-resolution audio and video. -
Versatile Compatibility
This HDMI cable supports multiple advanced technologies, including HDMI CEC support, allowing users to control compatible devices with one remote, enhancing convenience in any entertainment setup. -
Robust Performance
With support for HDR 10 and a data rate of 18 Gbps, this cable delivers an exceptional viewing experience, suitable for 4K content and gaming applications. -
Long-Lasting Durability
Designed with a lifespan of 10,000 insertions, the cable features a strain relief design and a thermoplastic elastomer jacket, ensuring it withstands regular use while maintaining performance.
 - StarTech.com 4m (13ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 4 m
- Cable
 - Premium High Speed - HDMI cable with Ethernet
- American Wire Gauge (AWG)
 - 28
- Length
 - 4 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - 4K60Hz support, passive cable
 - Limited lifetime warranty
- Cable Type
 - Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
 - 28
- Jacket Material
 - Thermoplastic elastomer (TPE)
- Shielding Material
 - Aluminum mylar foil with braid
- Length
 - 4 m
- Plated Connector
 - Gold
 - 18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), HDR 10 support, EMI protection, 10000 insertions lifespan, strain relief, outer diameter 7.3mm
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - RoHS, HDCP 2.2, halogen-free
 - 287 g
- Shipping Width
 - 22 cm
- Shipping Depth
 - 20 cm
- Shipping Height
 - 2 cm
- Shipping Weight
 - 291 g
 - Limited warranty - lifetime
