StarTech.com Premium Certified HDMI Cable 3m
Quicklinx: J1KRWS00 Mfr#: HDMI2-CABLE-4K60-3M
More than 50 In Stock
£8.98 ex VAT
£10.77 inc VAT
The 3 m Premium Certified High Speed HDMI Cable delivers performance with support for 4K resolution at 60 Hz. Its high-speed design ensures a clear and vibrant picture along with stunning audio quality. Built with advanced features like HDMI Ethernet Channel and Audio Return Channel, this cable enhances connectivity and reduces clutter in home theaters or gaming setups.
Constructed with aluminum mylar foil and braid shielding, this cable offers robust EMI protection, ensuring optimal signal integrity. It can handle 32 audio channels and supports HDR 10, allowing for an immersive audiovisual experience. The 30 AWG wiring and gold-plated connectors contribute to its durability and reliable performance, making it an ideal choice for high-definition entertainment.
  • Robust connectivity
    This HDMI cable is equipped with HDMI Ethernet Channel technology, allowing multiple devices to connect without the need for additional cables.
  • High quality design
    Constructed with 30 AWG wiring and thermoplastic elastomer jacket, this cable provides durability and effective strain relief.
  • Superior performance
    With support for 4K resolution at 60 Hz and an 18 Gbps data rate, this cable ensures a seamless and high-quality digital experience.
  • Enhanced audio capabilities
    It supports up to 32 audio channels and includes HDR 10 technology, providing a rich and immersive sound experience.
StarTech.com 3m (10ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 3 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
30
Length
3 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
3 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDR 10 support, 32 audio channels, cable diameter 6 mm, strain relief, EMI protection
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.2, halogen-free
215 g
Shipping Width
29 cm
Shipping Depth
14.5 cm
Shipping Height
2 cm
Shipping Weight
220 g
Limited warranty - lifetime
