StarTech.com Premium Certified HDMI Cable 3.6m
Quicklinx: J1M1WS00 Mfr#: HDMI2-CABLE-4K60-12F
£11.57 ex VAT
£13.88 inc VAT
Experience high-quality audio and video transmission with the StarTech.com 12ft Premium Certified High Speed HDMI Cable. This cable is designed for use with a range of HDMI devices, offering performance and reliability. With a robust construction that includes aluminum mylar foil shielding and a thermoplastic elastomer (TPE) jacket, it ensures durability while providing protection against electromagnetic interference. The cable supports 4K resolution at 60Hz and delivers an 18 Gbps data rate, making it suitable for high-bandwidth applications like streaming and gaming.
  • High-speed performance
    The HDMI cable boasts a data rate of 18 Gbps, allowing for quick and efficient transmission of high-definition video and audio signals.
  • Robust construction
    Constructed with aluminum mylar foil and braid shielding, this cable minimizes interference and provides a stable connection for reliable performance.
  • Durable design
    Featuring a thermoplastic elastomer (TPE) jacket and strain relief, the cable is designed to endure everyday use, ensuring longevity.
  • Versatile compatibility
    This HDMI cable supports features such as Audio Return Channel (ARC), HDMI CEC, and HDR 10, making it compatible with various devices and setups.
  • Certified quality
    With RoHS and halogen-free certifications, this HDMI cable meets stringent environmental standards, reflecting its high quality and safety.
StarTech.com 12ft (3.6m) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 3.7 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
28
Length
3.7 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
28
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
3.7 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), HDR 10 support, EMI protection, 10000 insertions lifespan, strain relief, outer diameter 7.3mm
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.2, halogen-free
220 g
Shipping Width
29 cm
Shipping Depth
14.5 cm
Shipping Height
2 cm
Shipping Weight
225 g
Limited warranty - lifetime
