Experience high-quality audio and video transmission with the StarTech.com 12ft Premium Certified High Speed HDMI Cable. This cable is designed for use with a range of HDMI devices, offering performance and reliability. With a robust construction that includes aluminum mylar foil shielding and a thermoplastic elastomer (TPE) jacket, it ensures durability while providing protection against electromagnetic interference. The cable supports 4K resolution at 60Hz and delivers an 18 Gbps data rate, making it suitable for high-bandwidth applications like streaming and gaming.
High-speed performance
The HDMI cable boasts a data rate of 18 Gbps, allowing for quick and efficient transmission of high-definition video and audio signals. -
Robust construction
Constructed with aluminum mylar foil and braid shielding, this cable minimizes interference and provides a stable connection for reliable performance. -
Durable design
Featuring a thermoplastic elastomer (TPE) jacket and strain relief, the cable is designed to endure everyday use, ensuring longevity. -
Versatile compatibility
This HDMI cable supports features such as Audio Return Channel (ARC), HDMI CEC, and HDR 10, making it compatible with various devices and setups. -
Certified quality
With RoHS and halogen-free certifications, this HDMI cable meets stringent environmental standards, reflecting its high quality and safety.
- StarTech.com 12ft (3.6m) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 3.7 m
- Cable
- Premium High Speed - HDMI cable with Ethernet
- American Wire Gauge (AWG)
- 28
- Length
- 3.7 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K60Hz support, passive cable
- Limited lifetime warranty
- Cable Type
- Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
- 28
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 3.7 m
- Plated Connector
- Gold
- 18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), HDR 10 support, EMI protection, 10000 insertions lifespan, strain relief, outer diameter 7.3mm
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS, HDCP 2.2, halogen-free
- 220 g
- Shipping Width
- 29 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 225 g
- Limited warranty - lifetime
