Experience enhanced audio and video quality with the 2m Premium Certified High Speed HDMI Cable from StarTech.com. With support for resolutions up to 4K at 60Hz and a data rate of 18 Gbps, this cable delivers a smooth visual experience. The construction features aluminum mylar foil shielding along with a braid to minimize electromagnetic interference, ensuring a reliable signal in any setup. This cable is designed for flexibility and durability, reinforced with strain relief and made from thermoplastic elastomer (TPE) for long-lasting use.
The StarTech.com HDMI cable supports HDR 10 and includes features such as an Audio Return Channel (ARC) and HDMI Ethernet Channel (HEC). With a passive design and gold-plated connectors, this cable efficiently transmits up to 32 audio channels, providing users with an immersive sound experience. Compliant with RoHS and HDCP 2.2 standards, this HDMI cable is suitable for both home and professional setups.
High-speed performance
This HDMI cable supports high-speed transmission with a data rate of 18 Gbps, ensuring flawless performance for both audio and video signals. -
Robust construction
Constructed with aluminum mylar foil and a braided shield, this cable minimizes electromagnetic interference, providing a stable connection. -
Versatile compatibility
Compatible with a variety of devices, this cable supports features like HDR 10, ARC, and HEC for an expansive range of connectivity. -
Durable design
Made from thermoplastic elastomer (TPE) with strain relief, this cable is designed to withstand daily wear and tear for long-lasting performance. -
Audio support
This cable supports up to 32 audio channels, enabling a rich sound experience suitable for home theaters and professional audio setups.
- StarTech.com 2m (6.6ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable - 2 m
- Cable
- Premium High Speed - HDMI cable
- American Wire Gauge (AWG)
- 30
- Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Passive cable, 4K60Hz support
- Limited lifetime warranty
- Cable Type
- Premium High Speed - HDMI cable passive, 4K60Hz support
- 30
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 2 m
- Plated Connector
- Gold
- HDMI Ethernet Channel (HEC), Audio Return Channel (ARC), HDR 10 support, 18 Gbps data rate, strain relief, 32 audio channels, EMI protection, cable diameter 6 mm
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS, halogen-free, HDCP 2.2
- 128 g
- Shipping Width
- 12.8 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 133 g
- Limited warranty - lifetime
