StarTech.com Premium Certified HDMI Cable 2m
Quicklinx: J1K5WS00 Mfr#: HDMI2-CABLE-4K60-2M
Hurry, only 2 left in stock!
£5.58 ex VAT
£6.69 inc VAT
Experience enhanced audio and video quality with the 2m Premium Certified High Speed HDMI Cable from StarTech.com. With support for resolutions up to 4K at 60Hz and a data rate of 18 Gbps, this cable delivers a smooth visual experience. The construction features aluminum mylar foil shielding along with a braid to minimize electromagnetic interference, ensuring a reliable signal in any setup. This cable is designed for flexibility and durability, reinforced with strain relief and made from thermoplastic elastomer (TPE) for long-lasting use.
The StarTech.com HDMI cable supports HDR 10 and includes features such as an Audio Return Channel (ARC) and HDMI Ethernet Channel (HEC). With a passive design and gold-plated connectors, this cable efficiently transmits up to 32 audio channels, providing users with an immersive sound experience. Compliant with RoHS and HDCP 2.2 standards, this HDMI cable is suitable for both home and professional setups.
  • High-speed performance
    This HDMI cable supports high-speed transmission with a data rate of 18 Gbps, ensuring flawless performance for both audio and video signals.
  • Robust construction
    Constructed with aluminum mylar foil and a braided shield, this cable minimizes electromagnetic interference, providing a stable connection.
  • Versatile compatibility
    Compatible with a variety of devices, this cable supports features like HDR 10, ARC, and HEC for an expansive range of connectivity.
  • Durable design
    Made from thermoplastic elastomer (TPE) with strain relief, this cable is designed to withstand daily wear and tear for long-lasting performance.
  • Audio support
    This cable supports up to 32 audio channels, enabling a rich sound experience suitable for home theaters and professional audio setups.
StarTech.com 2m (6.6ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable - 2 m
Cable
Premium High Speed - HDMI cable
American Wire Gauge (AWG)
30
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Passive cable, 4K60Hz support
Cable Type
Premium High Speed - HDMI cable passive, 4K60Hz support
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
2 m
Plated Connector
Gold
HDMI Ethernet Channel (HEC), Audio Return Channel (ARC), HDR 10 support, 18 Gbps data rate, strain relief, 32 audio channels, EMI protection, cable diameter 6 mm
Connector
19 pin HDMI Type A - male
RoHS, halogen-free, HDCP 2.2
128 g
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
2 cm
Shipping Weight
133 g
Limited warranty - lifetime
