The 1 m (3.3 ft) Premium Certified High Speed HDMI Cable from StarTech.com offers performance designed to meet the demands of high-definition audio and video. With support for 4K at 60 Hz, this HDMI cable ensures crisp visuals and immersive sound, making it an ideal choice for gaming, streaming, or connecting to your home theater system. Built with aluminum mylar foil shielding and a thermoplastic elastomer jacket, it provides durability and effective EMI protection against interference, ensuring a stable connection at all times.
This HDMI cable is equipped with technology features, including HDMI Ethernet Channel (HEC), Audio Return Channel (ARC), and HDR 10 support. With a data rate of 18 Gbps and the ability to transmit up to 32 audio channels, it delivers a rich audio experience while accommodating various devices. The strain relief feature enhances flexibility, while the gold-plated connectors ensure signal quality, making this cable a reliable addition to any entertainment setup.
Performance
The cable supports 4K 60 Hz resolution, ensuring a clear and crisp picture quality when connecting high-definition devices. -
Shielding
Built with aluminum mylar foil and braid, this cable minimizes electromagnetic interference for a stable and reliable signal. -
Audio capabilities
With support for 32 audio channels, this HDMI cable allows for a rich, immersive sound experience in home theater systems. -
Construction
The thermoplastic elastomer jacket offers flexibility and durability, while the strain relief feature enhances the cable's longevity. -
Data transmission
Boasting a data rate of 18 Gbps, this cable ensures fast and efficient transmission of both audio and video signals.
 - StarTech.com 1m (3.3ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 1 m
- Cable
 - Premium High Speed - HDMI cable with Ethernet
- American Wire Gauge (AWG)
 - 30
- Length
 - 1 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - 4K60Hz support, passive cable
 - Limited lifetime warranty
- Cable Type
 - Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
 - 30
- Jacket Material
 - Thermoplastic elastomer (TPE)
- Shielding Material
 - Aluminum mylar foil with braid
- Length
 - 1 m
- Plated Connector
 - Gold
 - 18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDR 10 support, 32 audio channels, cable diameter 6 mm, strain relief, EMI protection
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - RoHS, HDCP 2.2, halogen-free
 - Limited warranty - lifetime
