StarTech.com Power Strip Desk Mount - Clamp-on Power Strip Holder
Quicklinx: FKF4WS00 Mfr#: PWRSTRPCLMP
Device Type: Other
Type: Power Strip Mount
Device Screen Size: [N/A]
Colour: Black
£8.88 ex VAT
£10.65 inc VAT
Get easy access to your power outlets, by placing your power strip where you need it most. Mount your power strip to your desktop, table, or counter or other flat surface with this clamp-on power strip desk mount.
Save time and effort every day by keeping your power outlets close at hand. The clamp on power strip holder attaches easily to desks, tables, counters and other flat surfaces up to 2" (50 mm) thick. No more reaching under the desk to access your power cords. Plus, keeping power cords off the floor means they stay cleaner.
Adjust the width with ease with the spring-loaded design. The power strip desk clamp works with most power strips from 1.6" - 2.4" (40 mm - 60 mm) wide. The desk clamp comes with silicone pads to hold your power strip securely in place.
The power strip desk mount features integrated cable management to routes your cables neatly and minimize clutter. Plus, foam pads on the desk clamp protect the desk surface from scratches and scuffs.
  • Sturdy Construction
    Crafted from a combination of plastic and aluminum, this mounting clamp ensures reliability and resilience in various desk environments.
  • Environmentally Compliant
    Meets RoHS and REACH standards, ensuring that the materials used are safe for both users and the environment.
StarTech.com Power Strip Desk Mount - Clamp-on Power Strip Holder - Adjustable - Desk / Table Clamp for Power Strip (PWRSTRPCLMP) - power strip mounting clamp
Power strip mounting clamp
Placing / Mounting
Desk mountable
Product Material
Plastic, aluminium
10 cm x 6.8 cm x 6.4 cm
300 g
Placing / Mounting
Desk mountable
Product Material
Plastic, aluminium
10 cm
6.8 cm
6.4 cm
300 g
16 cm x 10.5 cm x 6.8 cm / 340 g
RoHS, REACH
Limited warranty: - 2 years
Device Type: Other
Colour: Black
