Create a wireless hot-spot from a wired network connection to share with any Wifi-enabled device. The R150WN1X1T Wireless N Travel Router lets you create a portable wireless hot-spot from a wired network connection, or an existing wireless network to share with all of your WiFi-enabled devices including tablets, laptops / Ultrabooks, or smartphones.
Support for several operating modes help you create, share or extend a wireless connection while traveling between hotel rooms, conference centers or boardrooms. The travel WiFi router offers a pocket-sized, USB-powered design with support for Wireless N data rates (backward compatible with 802.11b/g networks).
Directly configurable using any wireless device with a web browser, the travel router supports several additional operation modes including: WISP (Wireless Internet Service Provider - AP & Client) which lets you share an existing WiFi connection with multiple devices, or WiFi repeater mode which extends the coverage area of an existing wireless network to avoid dead spots.
The USB-powered wireless router is designed to fit directly over your iPad wall charger. For other USB wall chargers or an available USB port on a laptop, we've included a USB extension cable to power the device. The portable router also offers a front USB charge port, allowing you to charge your devices as needed.
- StarTech.com Portable Wireless N WiFi Travel Router for iPad w/ Charge Port - wireless router - Wi-Fi
- Wireless router
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 150 Mbps
- Remote Management Protocol
- HTTP
- Repeating mode, Access Point operational mode, USB powered
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- White
- 4.8 cm x 5.5 cm x 3.4 cm
- 335 g
- 2-year warranty
- Wireless router
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 150 Mbps
- Max Range Indoors
- 10 m
- HTTP
- Encryption Algorithm
- WPA, WPA2, WEP
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, RoHS
- Status Indicators
- Power, wireless
Line Properties
- Line Coding Format
- CCK, 64 QAM, BPSK, QPSK, 16 QAM
- 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A (power only)
- Enclosure Colour
- White
- Cables Included
- 1 x USB extension cable
- 4.8 cm
- 5.5 cm
- 3.4 cm
- 335 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 0 - 90% (non-condensing)
Expand your network
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R | In Stock | £12.77 |
