USB Type-C Video Converter , 1080p , Built-In Flex Cable , Mac & Windows . This compact USB-C to VGA adapter offers an ultra-portable solution for connecting your USB Type-C laptop or device to a high-definition VGA monitor, projector or other display. The converter is equipped with a removable, quick-connect keychain ring that easily attaches to your laptop or projector bag, maximizing portability.
Perfect Travel Companion
This lightweight USB-C to VGA display adapter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD (Bring Your Own Device) applications at the office or road warriors who need to connect on the go.
It's the perfect solution for:
Delivering professional presentations while in the office or traveling
Connecting your smartphone or tablet to a VGA monitor
Hot-desking environments
Keep Your Adapter with You
Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in 1.3" flex cable that has a folding design, adding to the compact form factor.
Plug-and-Play Connectivity
To ensure a hassle-free connection, this video adapter works with all your Mac and Windows USB Type-C devices and is also compatible with Thunderbolt 3 . It requires no additional software or drivers, supporting true plug-and-play connectivity.
CDP2VGAFC is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Perfect travel companion
This lightweight converter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD applications at the office or road warriors who need to connect on the go. -
Keep your adapter with you
Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in flex cable that has a folding design, adding to the compact form factor.
- StarTech.com Compact USB C to VGA Adapter, 1080p 60Hz USB Type-C to VGA Video Display Converter with Keychain Ring, Active USB-C DP Alt Mode to VGA Monitor Dongle, Thunderbolt 3 Compatible - USB-C Keychain Adapter (CDP2VGAFC) - adapter - VGA / USB
- Cable
- Adapter - VGA / USB
- Max Output Resolution
- 1920 x 1200 - 60 Hz
- Black
- Connectors
- 24 pin USB-C - male
- Connectors (Second End)
- HD-15 (VGA) - female
- 1080p support
- 3-year warranty
- Cable Type
- Adapter 1080p support
- Interface Supported
- VGA / USB
- DisplayPort Alternate Mode support, Realtek RTD2169U-CG chipset
- Black
Adapters & Converters
- 1920 x 1200
- Refresh Rate
- 60 Hz
- Connectors
- 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS, WEEE, REACH
- 4.8 cm
- 3.2 cm
- 1.4 cm
- 17 g
- Shipping Width
- 21.8 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 21.5 g
- Limited warranty - 3 years
