StarTech.com Portable USB C to DisplayPort Adapter w/ Keychain - 4K
Quicklinx: FNKLWS00 Mfr#: CDP2DPFC
£8.01 ex VAT
£9.61 inc VAT
HIGH PERFORMANCE: USB-C to DisplayPort 1.4 (32.4Gbps) adapter compatible w/ HDR/DisplayHDR, HBR3, Display Stream Compression (DSC), HDCP 2.2/1.4; 8K 60Hz (7680x4320), 5K 60Hz, 4K 120Hz & 1080p
PORTABLE DESIGN: Compact & lightweight USB-C to DisplayPort adapter is perfect for travelling; equipped with a flexible wrap-around cable & removable keychain ring that securely attaches to your bag
COMPATIBILITY: Dell XPS, Precision & Latitude, Lenovo ThinkPad X1 Carbon & Extreme, Microsoft Surface Book & Surface Laptop 3, MacBook Pro, TB3 MacBook Air, HP EliteBook, Spectre & ZBook & Chromebook
TESTED & VERIFIED: USB-C to DisplayPort video converter (male to female) compatible w/ range of 8K, 4K and 1080p DP monitors/displays incl brands like Dell Ultra Sharp, Samsung, Asus ProArt, Acer & LG
EASY TO USE: USB C to DP adapter dongle supports driverless plug & play setup & is compatible w/ macOS, Windows 10, Linux & Chrome OS; works w/ any USB Type-C or Thunderbolt 3 (DP Alt Mode) device
  • Perfect travel companion
    This lightweight USB-C to DP display adapter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD (Bring Your Own Device) applications at the office or road warriors who need to connect on the go.
  • Keep your adapter with you
    Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in 1.3" flex cable that has a folding design, adding to the compact form factor.
  • Plug-and-Play connectivity
    To ensure a hassle-free connection, this video adapter works with all your Mac and Windows USB Type-C devices and is also compatible with Thunderbolt 3. It requires no additional software or drivers, supporting true plug-and-play connectivity.
StarTech.com Compact USB C to DisplayPort 1.4 Adapter, 8K 60Hz/4K USB-C to DP Video Converter w/ Keychain Ring, USB Type-C DP Alt Mode (HBR3 HDR DSC) to DP Monitor Dongle, TB3 Compatible - USB-C Keychain Adapter (CDP2DPFC) - USB / DisplayPort adapter - 24 pin USB-C to DisplayPort
4K support, keychain design, 7.1 audio channel support
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - female (output)
Displayport 1.2/Thunderbolt 3
3-year warranty
Connector
Displayport 1.2/Thunderbolt 3, FCC, RoHS, REACH
3-year warranty
FNKL StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.28
FNKL StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.35
FNKL StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £11.54
