Perfect travel companion
This lightweight USB-C to DP display adapter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD (Bring Your Own Device) applications at the office or road warriors who need to connect on the go. -
Keep your adapter with you
Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in 1.3" flex cable that has a folding design, adding to the compact form factor. -
Plug-and-Play connectivity
To ensure a hassle-free connection, this video adapter works with all your Mac and Windows USB Type-C devices and is also compatible with Thunderbolt 3. It requires no additional software or drivers, supporting true plug-and-play connectivity.
- StarTech.com Compact USB C to DisplayPort 1.4 Adapter, 8K 60Hz/4K USB-C to DP Video Converter w/ Keychain Ring, USB Type-C DP Alt Mode (HBR3 HDR DSC) to DP Monitor Dongle, TB3 Compatible - USB-C Keychain Adapter (CDP2DPFC) - USB / DisplayPort adapter - 24 pin USB-C to DisplayPort
- 4K support, keychain design, 7.1 audio channel support
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 20 pin DisplayPort - female (output)
- Displayport 1.2/Thunderbolt 3
- Black
- 3-year warranty
- Black
- Connector
- Displayport 1.2/Thunderbolt 3, FCC, RoHS, REACH
- 3-year warranty
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.10 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.82 |
StarTech.com Portable USB C to Mini DisplayPort Adapter w/ Keychain | In Stock | £11.31 |
StarTech.com Portable USB C to VGA Adapter w/ Keychain | In Stock | £10.42 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.66 |
