StarTech.com Portable Laptop Stand
Quicklinx: D6QYWS00 Mfr#: LTRISERP
Device Type: Laptop
Type: Stand
Device Screen Size: [N/A]
Colour: Black
£16.91 ex VAT
£20.29 inc VAT
Work in comfort by positioning your laptop closer to eye level, with six adjustable angle settings. This portable laptop stand enables you to adjust the position of your laptop according to your line of sight, to increase your comfort and productivity. It's fully adjustable with six angles, and features a compact, lightweight design, so you can take it along with your laptop to enhance your workstation anywhere you go.
Placing your laptop for easy viewing helps to reduce neck and back strain. This laptop riser helps you to maintain better posture and work more comfortably, with six adjustable tilt angle options (15°, 17°, 19°, 35°, 37°, and 39°) to customize your work setup. Adjusting the angle of your laptop also provides a more ergonomic keyboard position.
The platform's adjustable angle and flow-through design helps to increase airflow and keep your laptop cool while you're using it. This passive-cooling design silently protects your laptop from overheating, and helps to prevent unwanted problems due to overheating, such as slower performance and malfunctions.
Its compact design (11.3" x 8.3" / 287 mm x 210 mm) provides a stable platform for your laptop, such as MacBook Pro, MacBook Air, Lenovo ThinkPad, HP, Asus or Dell Ultrabook . You can also use this laptop riser to hold your tablet in a comfortable position, keeping both hands free so you can type and swipe.
This portable laptop riser is easy to carry around, so you can enhance your workstation wherever you go. The riser is easy to fold up and carry in your laptop bag. It's ultra-thin (10 mm) and extremely lightweight (358 g), which is ideal for mobile use.
  • Versatile compatibility
    This stand accommodates notebooks ranging from 9 inches to 13 inches in size, making it perfect for various devices.
  • Adjustable height
    Easily adjust the height of the stand to create a comfortable viewing experience tailored to user preferences.
  • Ergonomic tilt
    The stand features a tilt adjustment of 15° to 39°, allowing users to find the perfect angle to reduce neck and back strain.
  • Portable design
    Equipped with a convenient handle, this laptop stand is easy to transport, ideal for users who travel frequently.
  • Stable grip
    The rubber grip ensures that the stand remains securely in place, providing a solid base for devices while in use.
StarTech.com Portable Laptop Stand - Adjustable Laptop Stand - Ergonomic Laptop Desk Stand - Laptop Riser for Desk (LTRISERP) - notebook / tablet stand - TAA Compliant
Notebook / tablet stand
Placing / Mounting
Desktop
28.7 cm x 21 cm x 1.1 cm
430 g
Notebook Compatibility
13"
Notebook Supported Sizes
9" - 13" / 22.9 cm - 33 cm
Handle, rubber grip, tilt adjustment 15° to 39°
TAA Compliant
Placing / Mounting
Desktop
28.7 cm
21 cm
1.1 cm
430 g
13"
Notebook Compatibility Dimensions
28.7 cm x 21 cm
TAA Compliant
Limited warranty: - 2 years
D6QY StarTech.com Sit-to-Stand Workstation In Stock £121.36
D6QY StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £70.33
D6QY StarTech.com Under Desk Keyboard Tray In Stock £55.81
D6QY StarTech.com Monitor Riser Stand for up to 34" Monitors In Stock £16.09
D6QY StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £31.68
D6QY StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £32.71
D6QY StarTech.com 15in Laptop Privacy Screen - Magnetic - 16:10 Aspect Ratio In Stock £46.69
D6QY StarTech.com Laptop Stand - 2-in-1 Riser/Vertical Stand In Stock £24.47
D6QY StarTech.com Laptop Riser Stand, Ergonomic In Stock £28.27
Device Type: Laptop
Type: Stand
Colour: Black
