Work in comfort by positioning your laptop closer to eye level, with six adjustable angle settings. This portable laptop stand enables you to adjust the position of your laptop according to your line of sight, to increase your comfort and productivity. It's fully adjustable with six angles, and features a compact, lightweight design, so you can take it along with your laptop to enhance your workstation anywhere you go.
Placing your laptop for easy viewing helps to reduce neck and back strain. This laptop riser helps you to maintain better posture and work more comfortably, with six adjustable tilt angle options (15°, 17°, 19°, 35°, 37°, and 39°) to customize your work setup. Adjusting the angle of your laptop also provides a more ergonomic keyboard position.
The platform's adjustable angle and flow-through design helps to increase airflow and keep your laptop cool while you're using it. This passive-cooling design silently protects your laptop from overheating, and helps to prevent unwanted problems due to overheating, such as slower performance and malfunctions.
Its compact design (11.3" x 8.3" / 287 mm x 210 mm) provides a stable platform for your laptop, such as MacBook Pro, MacBook Air, Lenovo ThinkPad, HP, Asus or Dell Ultrabook . You can also use this laptop riser to hold your tablet in a comfortable position, keeping both hands free so you can type and swipe.
This portable laptop riser is easy to carry around, so you can enhance your workstation wherever you go. The riser is easy to fold up and carry in your laptop bag. It's ultra-thin (10 mm) and extremely lightweight (358 g), which is ideal for mobile use.
Versatile compatibility
This stand accommodates notebooks ranging from 9 inches to 13 inches in size, making it perfect for various devices. -
Adjustable height
Easily adjust the height of the stand to create a comfortable viewing experience tailored to user preferences. -
Ergonomic tilt
The stand features a tilt adjustment of 15° to 39°, allowing users to find the perfect angle to reduce neck and back strain. -
Portable design
Equipped with a convenient handle, this laptop stand is easy to transport, ideal for users who travel frequently. -
Stable grip
The rubber grip ensures that the stand remains securely in place, providing a solid base for devices while in use.
- StarTech.com Portable Laptop Stand - Adjustable Laptop Stand - Ergonomic Laptop Desk Stand - Laptop Riser for Desk (LTRISERP) - notebook / tablet stand - TAA Compliant
- Product Type
- Notebook / tablet stand
- Placing / Mounting
- Desktop
- 28.7 cm x 21 cm x 1.1 cm
- 430 g
- Notebook Compatibility
- 13"
- Notebook Supported Sizes
- 9" - 13" / 22.9 cm - 33 cm
- Handle, rubber grip, tilt adjustment 15° to 39°
- TAA Compliant
- 2-year warranty
- Product Type
- Desktop
- 28.7 cm
- 21 cm
- 1.1 cm
- 430 g
- 13"
- Notebook Compatibility Dimensions
- 28.7 cm x 21 cm
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Sit-to-Stand Workstation | In Stock | £121.36 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £68.98 |
StarTech.com Under Desk Keyboard Tray | In Stock | £52.06 |
StarTech.com Monitor Riser Stand for up to 34" Monitors | In Stock | £16.34 |
StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £31.60 |
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £32.64 |
StarTech.com Laptop Stand - 2-in-1 Riser/Vertical Stand | In Stock | £23.87 |
StarTech.com Laptop Riser Stand, Ergonomic | In Stock | £28.14 |
