StarTech.com Portable 4pt USB-C Hub, 10Gbps
Quicklinx: H13XWS00 Mfr#: HB31CM1A3CB
Type: USB Hub
Interface: USB 3.2, USB 3.1 Type C
Speed: 10Gbps
Ports: 4
Form Factor: External
£32.62 ex VAT
£39.14 inc VAT
This 4-Port USB-C Hub expands the connectivity of a USB-C laptop. This hub features four USB 3.2 Gen 2 (10Gbps) enabled ports, three USB-C and one USB-A, that support high-bandwidth USB peripherals. Connect the attached USB-C cable to a USB Type-C or Thunderbolt 3/4 port, located on the host computer, to enable the quick connection of up to 4 peripherals.
  • Convenient Portability and Easy Setup
    This USB-C hub is a compact and lightweight portable laptop accessory.?It draws up to 15 Watts of power from the host laptop. The hub is bus powered and provides up to 2A of power to each port. The attached cable measures 9.8in (25cm) in length. This cable can be stored when the hub is being transported in a laptop bag, facilitating tangle-free stow-away portability.
  • USB-C & USB-A Compatibility
    With one Type-A and three Type-C ports, and backward compatibility with USB 3.2 Gen 1 (5Gbps) and USB 2.0 (480Mbps), this USB hub supports new and legacy USB devices. Connect flash drives, video capture devices and external hard drives, with data transfer speeds of up to 10Gbps. This USB Type-C hub enhances productivity, providing the connections needed for the efficient use of multiple peripherals.
  • Hassle-Free Plug-and-Play Installation
    The 4-Port USB Hub is OS independent. It supports all operating systems including Windows, macOS, ChromeOS, iPad OS and Android. This adapter is plug-and-play, requiring no software or drivers. This product is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 4-Port USB-C Hub, 1x USB-A and 3x USB-C Ports, USB 3.1 10Gbps, Bus Powered, USB Type C Hub with 9.8in (25cm) Wrap-Around Cable, Portable USB-C to USB-A Hub - USB Expansion Hub (HB31CM1A3CB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
1 x USB 3.2 Gen 2 + 3 x USB-C 3.2 Gen 2
Performance
Data transfer rate: 10 Gbps
USB powered, plastic housing, downstream
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
6.2 cm x 13.5 cm x 2 cm
89 g
Space grey
Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
3-year warranty
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Performance
X VIA Labs / Realtek RTS5423 / VL160
1 x USB 3.2 Gen 2 Type A , 3 x USB 3.2 Gen 2 Type C
Space grey
1 x USB-C cable - 25 cm
Plug and Play, FCC, RoHS, WEEE, RCM
6.2 cm
13.5 cm
2 cm
89 g
Shipping Width
14.2 cm
Shipping Depth
17.3 cm
Shipping Height
3 cm
Shipping Weight
147 g
Limited warranty - 3 years
-20 °C
60 °C
0 - 85% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
80 °C
H13X StarTech.com 10-Port USB-C Hub Self-Powered In Stock £115.46
H13X StarTech.com 7-Port USB-C Hub, Self-Powered In Stock £106.95
Type: USB Hub
Interface: USB 3.2
Interface: USB 3.1 Type C
Speed: 10Gbps
Ports: 4
