The StarTech.com Serial to Ethernet Adapter is a versatile connectivity solution designed to bridge the gap between RS232 DB9 devices and IP-based networks. With its robust metal housing and advanced electrostatic discharge protection, it offers reliability and durability in various operational environments, from industrial settings to office spaces. The adapter supports Power over Ethernet (PoE), allowing for a cleaner setup with fewer cables and no need for external power supplies. It features a comprehensive suite of network functionalities including auto-negotiation, full duplex capability, and static IP routing, ensuring efficient and manageable network integration. Furthermore, the device is equipped with remote management capabilities, enabling secure and straightforward configuration and monitoring over the network. Whether it's for connecting surveillance cameras, point of sale systems, or industrial equipment, the StarTech.com Serial to Ethernet Adapter provides a reliable, efficient, and secure way to extend your network connectivity.
Robust connectivity
Equipped with both RS-232 and 100Base-TX (PoE) interfaces, this Serial to Ethernet Adapter ensures versatile connectivity options for a wide range of devices, making it an ideal solution for diverse operational environments. -
Enhanced durability
The metal housing and electrostatic discharge protection up to 15 kV provide a durable solution that can withstand harsh industrial environments, ensuring reliable performance and longevity. -
Efficient power management
With Power over Ethernet (PoE) capability, this adapter simplifies installation by eliminating the need for a separate power supply, offering a streamlined setup and reducing clutter. -
Advanced network features
Features such as auto-negotiation, full duplex capability, and static IP routing support efficient network communication and management, enhancing the adapter's performance in complex network infrastructures. -
Secure remote management
Support for Telnet and UDP remote management protocols allows for secure and convenient configuration and monitoring of the adapter, facilitating efficient management of networked devices.
- StarTech.com Serial to Ethernet Adapter, IP LAN to RS232 DB9 Converter - device server - PoE - TAA Compliant
- Device server
- Form Factor
- Wall / DIN rail mountable
- Data Link Protocol
- Ethernet, Fast Ethernet, RS-232
- Included Accessories
- Wall mounting kit, DIN-rail mounting kit
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11
- Power Over Ethernet (PoE) Supported
- PoE
- TAA Compliant
- 8.2 cm x 4.6 cm x 2.5 cm
- 155 g
- 2-year warranty
- Device server
- 8.2 cm
- 4.6 cm
- 2.5 cm
- 155 g
- Enclosure Colour
- Black
- Form Factor
- Connectivity Technology
- Wired
- Data Transfer Rate
- 921.6 Kbps
- Telnet, TCP, UDP
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- Telnet, UDP
- Status Indicators
- Link/activity, power, transmit, receive, PoE
- Metal housing, 15 KV Electrostatic Discharge Protection, 8 KV Contact Electrostatic Discharge Protection, auto-negotiation, flow control, adjustable parity, manageable, auto-uplink (auto MDI/MDI-X), full duplex capability
- IEEE 802.3af, IEEE 802.3u, IEEE 802.3i
- 1 x RS-232 - DB-9 , 1 x 100Base-TX (PoE) - RJ-45 - 15.4 W
- EIA/TIA-232
- TAA Compliant
- PoE
- Power Device
- External power adapter
- OS Required
- Shipping Width
- 20.7 cm
- Shipping Depth
- 14.4 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 1.2 kg
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 95% RH (non-condensing)
StarTech.com Slimline DB9 Serial Gender Changer - F/F | In Stock | £4.64 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.51 |
StarTech.com Serial to Ethernet Adapter | In Stock | £122.54 |
StarTech.com 2P Serial to Ethernet Adapter | In Stock | £187.92 |
StarTech.com 4P Serial to Ethernet Adapter | In Stock | £326.89 |
