StarTech.com PoE Injector & Splitter Kit
Quicklinx: F2GPWS00 Mfr#: UPOESPLT1G
£144.44 ex VAT
£173.32 inc VAT
This 60W PoE Injector + PoE Splitter Kit comes with a 60W Power over Ethernet injector, adding PoE via PoE.
Compliant with IEEE 802.3bt and supporting up to 60 watts of PoE, you can do more than just power your IP phone or wireless router. 60W PoE can support your higher-powered devices such as thin clients, POS systems, laptops or digital signage, from up to 100 meters away.
The PoE injector and PoE splitter are both simple to set up. Supporting plug-and-play installation, they also feature a compact, all-in-one design, and a durable, wall-mountable metal housing. The PoE splitter's 12V/19V/24V DIP switch on the front panel offers either 24V DC power to industrial equipment or 12V/19V DC output to common network devices, increasing the number of product applications.
StarTech.com offers networking products that extend your networks to remote locations at extreme distances, for maximum network scalability.
StarTech.com 1 Port Gigabit PoE Injector & Splitter Kit, 60W High Power over Ethernet Injector 100m/12-24V DC Splitter 802.3bt Midspan Single Port Ultra PoE LAN/RJ45 Security/Monitoring - PoE Injector/Splitter (UPOESPLT1G) - PoE injector + PoE splitter - 60 Watt
PoE injector + PoE splitter - external
Australia, Japan, North America, United Kingdom, Europe
Power Capacity
60 Watt
Black, brown
Black, brown
Input Voltage Range
AC 100 - 240 V
Power Capacity
60 Watt
1 x Gigabit LAN - RJ-45
Network cable
IEEE 802.3af, IEEE 802.3at, IEEE 802.3bt
50 °C
5 - 90% (non-condensing)
F2GP StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £355.82
F2GP StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £32.38
F2GP StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet In Stock £120.78
