StarTech.com PCIe Video Capture Card
Quicklinx: D5BGWS00 Mfr#: PEXHDCAP60L2
£222.07 ex VAT
£266.48 inc VAT
Use this dual-profile internal capture card to record 1080p video at 60 frames per second. This PCIe video capture card lets you record 1080p HD video and 2-channel stereo audio (HDMI/RCA) to your computer system. With multiple video inputs, including HDMI, DVI, VGA and component, this all-in-one capture card can record original content from virtually any device.
You can install the card into any low-profile or full-profile PCIe slot, including fixed workstations such as 2U or 4U rack-mounted servers or media centers. Installing your capture device internally through PCIe ensures a secure and reliable way to capture video.
With frame rates up to 60fps (frames per second) and H.264 encoding, this card is perfect for capturing high-definition video for editing, compiling, and archiving. The capture card supports 16:9 and 4:3 aspect ratios and lets you record lossless video at 60fps. This ensures that every frame of content is saved, unlike 30fps capture devices that only capture half the action.
60fps exactly matches the output of most computer video cards, which makes this capture card great for recording the output from your PC, server, or point-of-sale station, when creating software training and tutorial videos.
The included software encodes captured video in H.264 - the most widely adopted video compression standard in the world. This ensures your video captures are compatible with most device platforms such as PC, Mac, iOS and Android .
The software not only lets you capture and export videos, but it also lets you take screenshots, schedule recordings and instantly stream your video source over the internet using online services such as Twitch, and others.
This HD capture card can record lossless raw video, which makes it compatible with Microsoft DirectShow. This means you can record video using your preferred third-party DirectShow software, such as Open Broadcaster Software (OBS).
This adapter card features DVI-I signaling and multiple adapters to support many video input types. With multiple A/V input options, you can capture video from a wide variety of sources including HDMI, DVI, VGA, and component. You can also expand the capabilities of this capture card by using A/V adapters to record from other video sources such as SDI, using our SDI to HDMI converter (SDI2HD) (sold separately). Support for a variety of A/V devices and signals is ideal for archiving analog video footage into a digital database.
The capture device also includes easy-to-use software that's compatible with NTSC and PAL systems - a must-have for professional video archiving applications where source media can change from project to project.
This capture device will not record digitally encrypted content.
  • Versatile input options
    Supports multiple input formats including HDMI, VGA, DVI, and component video, allowing flexibility in connecting various devices.
  • Quality video capture
    Records at a digital video capture resolution of 1920 x 1080 at 60 frames per second, providing clear and fluid video output.
  • Compliant with standards
    Meets FCC and RoHS regulations, ensuring a reliable and eco-friendly product for users.
  • Adaptable installation
    Includes a low-profile bracket for compatibility with both full-height and low-profile cases, facilitating diverse PC configurations.
  • Robust operating conditions
    Functions effectively within a temperature range of 0°C to 40°C and humidity levels of 20% to 80%, ensuring performance in various environments.
StarTech.com PCIe Video Capture Card - 1080P at 60 FPS - HDMI / VGA / DVI / Component - PC Capture Card - Internal Capture Card (PEXHDCAP60L2) - video capture adapter - PCIe 2.0
Video capture adapter
Interface Type
PCIe 2.0
6.9 cm x 13.5 cm
300 g
Included Input Adapter Accessories
Low-profile bracket
Video Input
DVI-Analogue/Digital input, VGA input, HDMI input, component video input, composite video input
Video Modes
1080i, 1080p, 720p, 576i, 576p, 480i, 480p
Analogue Video Format
NTSC, PAL-M, PAL, PAL 60
Analogue video Signal
Composite video, component video
Digital Video Format
MPEG-4, H.264, AVI, FLV, TS
Digital Video Capture Speed
Digital Video Capture Resolution
1920 x 1080
Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Interface Type
PCIe 2.0
6.9 cm
13.5 cm
300 g
Video
Interface Type
Video Modes
1920 x 1080
1 x display / video - DVI-Digital (dual link) input - 24+5 pin combined DVI , 1 x display / video - composite video/component video input
Compatible Slots
1 x PCI Express 2.0 x1 - full-height
Low-profile bracket
1 x DVI-VGA adapter - external , 1 x component video cable - external , 1 x HDMI-DVI adapter - external , 1 x composite video cable - external
FCC, RoHS
System Requirements Details
Core i5 RAM 4 GB
20 - 80% (non-condensing)
D5BG StarTech.com HDMI Capture Card - PCIe - UHD 4K 60Hz - For Windows In Stock £149.00
