StarTech.com PCIe HDMI & VGA capture card
Quicklinx: BHZ1WS00 Mfr#: PEXHDCAP60L
Capture a 1080p HDMI, DVI, VGA or Component Audio-Video source at 60 frames per second, through a low-profile or full-profile PCI Express slot. This all-in-one PCI Express capture card lets you record 1080p HD video and stereo audio to your computer system. With multiple video inputs including HDMI, DVI, VGA and component, the capture card can record original content from various sources such as computers, camcorders, security systems, POS terminals, and servers. With a framerate of 60 FPS (frames per second) and H.264 encoding, this is the perfect solution for capturing high-definition video for editing, compiling, and archiving.
The card can be installed into any low-profile or full-profile PCIe slot, making it the ideal solution for fixed workstations such as 2U or 4U rack-mounted servers or media centers. Installing your capture device internally via PCIe ensures a secure and reliable solution for video capture.
This capture card lets you record lossless video at 60 FPS ensuring every frame of content is saved, unlike 30-frame-per-second capture devices that only catch half the action. 60 FPS exactly matches the output of most computer video cards, which is great for recording the output from your PC, server, or POS station when creating software training and tutorial videos.
The included software encodes in H.264, the most widely adopted video codec in the world, ensuring your video captures will be compatible with almost any device platform such as PC, Mac, iOS and Android with no editing or converting required. H.264 is also widely supported by most software titles including Adobe Premiere and Windows Media Encoder. Plus, the software not only lets you capture and export videos, but it also lets you take screenshots, schedule recordings and instantly stream your video source over the Internet using online services such as Twitch or Justin.TV.
This card is capable of capturing lossless raw video making it compatible with Microsoft DirectShow. With raw video capture you can record video using your preferred third party DirectShow software such as Open Broadcaster Software (OBS).
With multiple A/V input options you can capture from a wide variety of sources including HDMI, DVI, VGA, and component. You can also use this capture card with A/V adapters to record other video sources such as SDI using the SDI to HDMI converter (SDI2HD). Support for a variety of A/V devices is ideal for archiving analog video footage into a digital database.
The device also includes easy-to-use software that's compatible with NTSC and PAL systems, making it a must for professional video archiving applications where source media can change from project to project.
Will not record digitally-encrypted content.
StarTech.com PCI Express HD Video Capture Card 1080p - video capture adapter - PCIe
Video capture adapter
Interface Type
PCIe
Included Input Adapter Accessories
Low-profile bracket
Video Input
DVI-Analog/Digital, component video input, HDMI
Analogue Video Format
NTSC, PAL, PAL-M, PAL 60
Analogue video Signal
Component video
Digital Video Format
MPEG-4, H.264
Digital Video Capture Resolution
1280 x 720, 1280 x 960, 1024 x 768, 1280 x 1024, 800 x 600, 1080 x 720, 1920 x 1080, 1440 x 900
Windows 10 (32/64 bits)
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
Interface Type
PCIe
Video
Interface Type
Component video
MPEG-4, H.264
2 x audio - RCA , 1 x display / video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x display / video - HDMI input - 19 pin HDMI Type A
Compatible Slots
1 x PCI Express x1
Low-profile bracket
1 x DVI-VGA adapter
FCC, RoHS
