StarTech.com PCIe Fiber Optic NIC w/ SFP+
Quicklinx: CGGZWS00 Mfr#: PEX10000SRI
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Compatibility: PC, Unix
Type: Network adapter
Hurry, only 2 left in stock!
£266.07 ex VAT
£319.28 inc VAT
Get high performance connectivity over multi-mode fiber, by upgrading your server or workstation with a 10GBase-SR port. This fiber optic network card delivers reliable, high-performance network connectivity, providing an easy and cost-effective way to upgrade your server or workstation to 10 Gigabit networking over multimode fiber. The 10G network card comes with an installed multimode SFP+ transceiver with up to 330 m range, to get you up and running quickly.
Increasing numbers of network users and data-intensive applications, such as multimedia streaming and large file transfers, all drive the need to increase the bandwidth capability of your network infrastructure. This fiber NIC lets you take advantage of the increased speed and stability of a 10 Gigabit network, with data transfers of up to 10Gbps and up to 20Gbps (full duplex) bandwidth.
For added convenience, this single-port 10G network card comes with an installed multimode SFP+ transceiver. Built to ensure reliable performance, the 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. The 10GBase-SR SFP+ delivers 10 Gigabit connectivity over multimode fiber cable with a range of up to 330 m (1082 ft).
The 10 Gigabit network card features the Intel 82599 chipset, delivering the power, performance and enhanced capabilities you need for reliable network connections to your server or computer. The Intel chip offers many advanced features including Intel Virtualization Technology for Connectivity, PXE network boot support and up to 15K jumbo frame support.
The 10G NIC connects easily through an available PCI Express expansion slot, and is compliant with PCIe Rev. 2 x8 (or higher). The network card comes with a standard profile, and also includes a low-profile bracket, for versatile installation.
StarTech.com 10G Network Card - 1x 10G Open SFP+ Multimode LC Fiber Connector - Intel 82599 Chip - Gigabit Ethernet Card (PEX10000SRI) - network adapter - PCIe x8
Network adapter
Plug-in card
Bundled with
10GBase-SR SFP+ transceiver module
Interface (Bus) Type
PCI Express x8
1.8 cm x 13.5 cm x 12 cm
Cabling Type
Ethernet 10GBase-SR
10 GigE
Data Transfer Rate
20 Gbps
Jumbo frame size: 15000
Intel 82599
IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP)
Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x LTS versions, Microsoft Windows Server 2019 (64-bit)
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
Network adapter
Plug-in card
Bundled with
PCI Express x8
Wired
Cabling Type
Ethernet 10GBase-SR
10 Gigabit Ethernet
Data Transfer Rate
20 Gbps
Status Indicators
Link/activity
Flow control, full duplex capability, Jumbo Frames support
Processor / Memory
Intel 82599
1 - SFP+
Low-profile bracket
FCC, RoHS
1.8 cm
13.5 cm
12 cm
5 °C
50 °C
20 - 80%
CGGZ StarTech.com PCIe 10Gb Fiber Card SFP+ NIC In Stock £149.01
CGGZ StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £226.06
CGGZ StarTech.com 10G Open SFP+ NIC - PCIe In Stock £167.63
CGGZ StarTech.com PCIe Fiber Optic NIC w/ SFP+ In Stock £266.07
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 150 - 300
