Add serial communication support to a Small Form Factor (SFF) or full-size system, using this two-port serial card. RS-232 (DB9) support enables control and communication with serial peripheral devices.
Legacy Connectivity
Install this card to enable the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The 2-port PCIe serial card is ideal for system upgrades in a wide range of applications for logistics, manufacturing, and freight sectors, and the IT industry, such as POS equipment, security systems, A/V installations, and more. -
Connect with Ease
The RS-232 card features dual ports with 16C1050 UART support, 256-byte FIFO (transmit/receive), bi-directional speeds up to 921.6 Kbps per port, low-profile brackets are included for SFF systems, and serial port LED status lights. In addition, it supports Windows and Linux systems for maximum compatibility. 21050-PC-SERIAL-LP is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 2-Port PCI Express Serial Card, Dual Port PCIe to RS232 (DB9) Serial Interface Card, 16C1050 UART, Standard or Low Profile Brackets, COM Retention, For Windows & Linux - PCIe to Dual DB9 Card (21050-PC-SERIAL-LP) - serial adapter - PCIe 2.0 - RS-232 x 2
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x1
- PCI Specification Revision
- PCIe 2.0
- Ports
- RS-232 x 2
- 6.6 cm x 6.7 cm x 1.8 cm
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- 16C1050 UART
- Yellow
- System Requirements
- Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux 2.6.13 or later
- 2-year warranty
- Serial adapter
- Form Factor
- PCIe 2.0
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- Status Indicators
- Status
- 256-byte FIFO
- 16C1050 UART
- 2 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
- Included Accessories
- Low-profile bracket
- Yellow
- OS Required
- 6.6 cm
- 6.7 cm
- 1.8 cm
- Shipping Width
- 20.7 cm
- Shipping Depth
- 14.4 cm
- Shipping Height
- 3.8 cm
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
