Brand
StarTech.com PCIe Dual Serial Port Card
Quicklinx: H788WS00 Mfr#: 21050-PC-SERIAL-LP
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Type: Serial adapter
12 In Stock
£48.46 ex VAT
£58.15 inc VAT
Add serial communication support to a Small Form Factor (SFF) or full-size system, using this two-port serial card. RS-232 (DB9) support enables control and communication with serial peripheral devices.
  • Legacy Connectivity
    Install this card to enable the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The 2-port PCIe serial card is ideal for system upgrades in a wide range of applications for logistics, manufacturing, and freight sectors, and the IT industry, such as POS equipment, security systems, A/V installations, and more.
  • Connect with Ease
    The RS-232 card features dual ports with 16C1050 UART support, 256-byte FIFO (transmit/receive), bi-directional speeds up to 921.6 Kbps per port, low-profile brackets are included for SFF systems, and serial port LED status lights. In addition, it supports Windows and Linux systems for maximum compatibility. 21050-PC-SERIAL-LP is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 2-Port PCI Express Serial Card, Dual Port PCIe to RS232 (DB9) Serial Interface Card, 16C1050 UART, Standard or Low Profile Brackets, COM Retention, For Windows & Linux - PCIe to Dual DB9 Card (21050-PC-SERIAL-LP) - serial adapter - PCIe 2.0 - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
PCI Specification Revision
PCIe 2.0
Ports
RS-232 x 2
6.6 cm x 6.7 cm x 1.8 cm
RS-232
Data Transfer Rate
921.6 Kbps
16C1050 UART
Yellow
Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux 2.6.13 or later
Serial adapter
PCI Express 2.0 x1
PCIe 2.0
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Status
256-byte FIFO
16C1050 UART
2 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
Low-profile bracket
Yellow
6.6 cm
6.7 cm
1.8 cm
Shipping Width
20.7 cm
Shipping Depth
14.4 cm
Shipping Height
3.8 cm
55 °C
5 - 95%
Protocol: RS-232
