Add serial communication support to your desktop computer or Small Form Factor (SFF) system, using this two-port serial card. RS-232 (DB9) support enables control and communication with a serial peripheral device.
Legacy Connectivity
Install this card to enable the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The 2-port PCIe serial card is ideal for system upgrades in a wide range of applications for logistics, manufacturing, and freight sectors, and the IT industry, such as POS equipment, security systems, A/V installations, and more. -
Connect with Ease
The RS-232 card features dual ports with 16C1050 UART support, 256-byte FIFO (transmit/receive), bi-directional speeds up to 921.6 Kbps per port, low-profile brackets are included for SFF systems, and serial port LED status lights. In addition, it supports Windows and Linux systems for maximum compatibility. 21050-PC-SERIAL-CARD is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
 - StarTech.com 2-Port PCI Express Serial Card, Dual Port PCIe to RS232 (DB9) Serial Interface Card, 16C1050 UART, Standard or Low Profile Brackets, COM Retention, For Windows & Linux - PCIe to Dual DB9 Card (21050-PC-SERIAL-CARD) - serial adapter - PCIe 2.0 - RS-232 x 2
 - Serial adapter
- Form Factor
 - Plug-in card - low profile
- Interface (Bus) Type
 - PCI Express 2.0 x1
- PCI Specification Revision
 - PCIe 2.0
- Ports
 - RS-232 x 2
 - 1.8 cm x 6.5 cm x 6.7 cm
- Data Link Protocol
 - RS-232
- Data Transfer Rate
 - 921.6 Kbps
 - 16C1050 UART
 - Yellow
- System Requirements
 - Linux, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 10 / 11
 - 2-year warranty
 - Serial adapter
- Form Factor
 - PCIe 2.0
- Ports
 - RS-232 x 2
- Connectivity Technology
 - Wired
 - RS-232
 - 921.6 Kbps
- Status Indicators
 - Status
 - 256-byte FIFO
 - 16C1050 UART
 - 2 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
- Included Accessories
 - Low-profile bracket
 - Yellow
- OS Required
 - 1.8 cm
 - 6.5 cm
 - 6.7 cm
- Shipping Width
 - 20.7 cm
- Shipping Depth
 - 14.4 cm
- Shipping Height
 - 3.8 cm
- Shipping Weight
 - 200 g
 - Limited warranty - 2 years
 - 0 °C
 - 55 °C
 - 5 - 95%
                        StarTech.com 2-Port Serial PCIe Card | In Stock | £63.15 |
