Brand
StarTech.com PCIe Dual Serial Port Card
Quicklinx: GVKLWS00 Mfr#: 21050-PC-SERIAL-CARD
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Type: Serial adapter
10 In Stock
£49.01 ex VAT
£58.81 inc VAT
Add serial communication support to your desktop computer or Small Form Factor (SFF) system, using this two-port serial card. RS-232 (DB9) support enables control and communication with a serial peripheral device.
  • Legacy Connectivity
    Install this card to enable the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The 2-port PCIe serial card is ideal for system upgrades in a wide range of applications for logistics, manufacturing, and freight sectors, and the IT industry, such as POS equipment, security systems, A/V installations, and more.
  • Connect with Ease
    The RS-232 card features dual ports with 16C1050 UART support, 256-byte FIFO (transmit/receive), bi-directional speeds up to 921.6 Kbps per port, low-profile brackets are included for SFF systems, and serial port LED status lights. In addition, it supports Windows and Linux systems for maximum compatibility. 21050-PC-SERIAL-CARD is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 2-Port PCI Express Serial Card, Dual Port PCIe to RS232 (DB9) Serial Interface Card, 16C1050 UART, Standard or Low Profile Brackets, COM Retention, For Windows & Linux - PCIe to Dual DB9 Card (21050-PC-SERIAL-CARD) - serial adapter - PCIe 2.0 - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
PCI Specification Revision
PCIe 2.0
Ports
RS-232 x 2
1.8 cm x 6.5 cm x 6.7 cm
RS-232
Data Transfer Rate
921.6 Kbps
16C1050 UART
Yellow
Linux, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 10 / 11
Serial adapter
PCI Express 2.0 x1
PCIe 2.0
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Status
256-byte FIFO
16C1050 UART
2 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
Low-profile bracket
Yellow
1.8 cm
6.5 cm
6.7 cm
Shipping Width
20.7 cm
Shipping Depth
14.4 cm
Shipping Height
3.8 cm
Shipping Weight
200 g
55 °C
5 - 95%
Protocol: RS-232
