StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo
Quicklinx: G7V3WS00 Mfr#: PEX1S1P950
Wired / Wireless: Wired
Protocol: RS-232, Parallel
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Parallel/serial adapter
£33.15 ex VAT
£39.78 inc VAT
PCI-Express 2.0 - RS-232 Serial - IEEE 1284 Parallel - Lifetime Warranty
This PCIe Parallel and Serial Combo Card installs into a single PCI-Express x1 slot in your computer, and adds a DB25 IEEE 1284 parallel port and DB9 RS 232 serial port to your system. The PEX1S1P950 is the latest version of our popular PEX1S1P952 combo card.
Adds an LPT Parallel Port
The controller card features an Asix AX99100 chip and enables you to connect a DB25 device to your desktop computer. The parallel port is ideal for connecting printers, scanners, plotters, point-of-sale terminals, PLCs, scientific sensors, medical equipment or oscilloscopes. The card can also be used in factories, to control or automate equipment. The parallel (LPT) port supports SPP/Byte/Nibble/ECP modes and is compatible with PCI Power Management 1.2 and IEEE 1284 for speeds up to 2.5Mbps.
Adds a COM Serial Port
The Asix AX99100 chip also enables you to connect a DB9 device using the same controller card, compatible with industry standard 16950 UART. The serial port is ideal for connecting point of sale terminals, serial printers, PLCs, control/automation in factories, scientific sensors, medical equipment, scanners and oscilloscopes. The serial (COM) port supports bi-directional RS232 speeds up to 921.6Kbps per port, available 256 byte FIFO buffer & 9th data bit. The card also features an optional SATA power input that enables you to add power to pin 9 on the serial port, and adjusted the power output between 5V and 12V using a jumper on the PCB.
Wide Installation Compatibility
This add-on card installs in a full/standard-profile PCIe 2.0 x1 slot (backward compatible with PCIe 1.1). For wide platform support the card is compatible with Windows (7 or higher), Windows Server (2003 or higher), and Linux (2.6.X or higher).
PEX1S1P950 is backed by a StarTech.com lifetime warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Adds an LPT Parallel port
  • Adds a COM Serial port
    The Asix AX99100 chip also enables you to connect a DB9 device using the same controller card, compatible with industry standard 16950 UART. The serial port is ideal for connecting point of sale terminals, serial printers, PLCs, control/automation in factories, scientific sensors, medical equipment, scanners and oscilloscopes. The serial (COM) port supports bi-directional RS232 speeds up to 921.6Kbps per port, available 256-byte FIFO buffer & 9th data bit. The card also features an optional SATA power input that enables you to add power to pin 9 on the serial port, and adjusted the power output between 5V and 12V using a jumper on the PCB.
  • Wide installation compatibility
StarTech.com PCIe Card with Serial and Parallel Port, PCI Express Combo Adapter Card with 1x DB25 Parallel Port & 1x RS232 DB9 Serial Port, Expansion/Controller Card, PCIe Printer Card - Full/Standard Profile (PEX1S1P950) - parallel/serial adapter - PCIe 2.0 - IEEE 1284 x 1 + RS-232 x 1
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
PCI Specification Revision
PCIe 2.0
Ports
9.5 cm x 8 cm x 2.2 cm
63 g
Parallel, RS-232
Data Transfer Rate
2.5 Mbps
ASIX AX99100
Red
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.4.x - 2.6.x LTS versions only
PCI Express 2.0 x1
PCIe 2.0
Ports
Wired
Parallel, RS-232
Data Transfer Rate
2.5 Mbps
Flow control, 256-byte FIFO
Processor / Memory
ASIX AX99100
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 1 x RS-232 - 9 pin D-Sub (DB-9)
MTBF
3,188,058 hours
WHQL, FCC, RoHS
Red
9.5 cm
8 cm
2.2 cm
63 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
127 g
Limited warranty - technical support - lifetime
-40 °C
85 °C
15 - 90%
Protocol: RS-232
Protocol: Parallel
