The PEX1PCI1R PCI Express to PCI riser card (left-angle) lets you install a 32-bit PCI card into the (x1) PCIe slot on an Intel 1U IPC rackmount chassis - a necessary accessory for almost any Intel 1U chassis, providing a simple way to expand system capabilities by adding I/O ports or a legacy PCI card to newer systems.
- StarTech.com PCI Express to PCI Riser Card x1 for Intel 1U IPC Server - riser card
- Product Type
- Riser card
- 2.7 cm x 17 cm x 2 cm
- 30 g
- 2-year warranty
- Product Type
- Riser card
- 2.7 cm
- 17 cm
- 2 cm
- 30 g
- Expansion Slots
- 1 (total) / 1 (free) x PCI
- Compatible Slots
- 1 x PCI Express x1
- RoHS
- Limited warranty - 2 years , Technical support - lifetime
- 0 °C
- 60 °C
StarTech.com PCI Express to PCI Adapter Card | In Stock | £36.30 |
StarTech.com PCI to PCI Express Adapter Card | In Stock | £37.61 |
