StarTech.com PCI Express to 4 Slot PCI Expansion System
Quicklinx: 7B77WS00 Mfr#: PEX2PCI4
10 In Stock
£376.57 ex VAT
£451.88 inc VAT
Add four external PCI expansion card slots to a desktop computer. StarTech.com's innovative PCI Express to PCI Expansion Chassis provides a quick and simple solution to I/O expandability on almost any PCI Express (PCIe) enabled system. Adding external PCI slots to a server/workstation or laptop, this cost-effective and time-saving method of simply adding additional PCI cards to a server/workstation or providing a platform to be able to swap PCI add-in cards between a mobile and desktop setup is the optimal method of maximizing the I/O capabilities of new or existing systems.
The external expansion chassis adds four PCI slots (32-bit/33MHz) to the host computer system, through a single PCI Express connection. Providing total bandwidth of up to 250MBps from the x1 PCIe host controller card, which allows the host computer to function as though the cards in the expansion chassis were connected directly to the motherboard.
StarTech.com PCI Express to 4 Slot PCI Expansion System - PCIeo PCI expansion box - External PCI slot - PCI expansion chassis (PEX2PCI4) - system bus extender
System bus extender
Power adapter - external
P/N: SVA12M5NA
System bus extender
Expansion Slots
4 (total) / 4 (free) x PCI
Compatible Slots
1 x PCI Express x1
1 x DVI cable - external
FCC, RoHS
P/N: SVA12M5NA
7B77 StarTech.com PCI Express to PCI Adapter Card In Stock £36.30
7B77 StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £333.85
7B77 StarTech.com DC Power Adapter - 12V, 5A In Stock £44.00
