StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length
Quicklinx: 6BF8WS00 Mfr#: PEX2PCIE4L
Type: None
Compatibility: Mac, PC, Unix
Hurry, only 2 left in stock!
£246.73 ex VAT
£296.07 inc VAT
Add two PCI and two PCI Express expansion card slots to your desktop computer. The PEX2PCIE4L PCI/PCI Express Expansion Chassis provides a quick and simple I/O expansion solution to almost any PCI Express (PCIe) enabled system. Adding PCI/PCIe cards to a server or workstation, or providing a platform to swap cards between a mobile and desktop setup is a cost-effective and time-saving solution for maximizing the I/O capabilities of your system.
The external expansion chassis adds two full-length (38cm) PCI slots (32-bit/33MHz), as well as two PCIe x1 (single-lane) slots to a host computer through a single PCI Express connection. Providing total bandwidth up to 250MBps from the PCIe x1 host controller card allows the computer to function as though the expansion chassis cards were connected directly to the motherboard.
StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length - system bus extender
System bus extender
38.2 cm x 13.7 cm x 14.3 cm
4 kg
Power adapter - internal AC 120/230 V
P/N: PCI1PEX1
System bus extender
38.2 cm
13.7 cm
14.3 cm
4 kg
Enclosure Colour
Expansion Slots
2 (total) / 2 (free) x PCI
Compatible Slots
2 x PCI Express x1
1 x DVI cable - external - 91 cm
FCC, RoHS
AC 120/230 V
55 °C
StarTech.com PCI to PCI Express Adapter Card
6BF8 StarTech.com 20 ft DVI-D Single Link Cable - M/M In Stock £18.57
6BF8 StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
6BF8 StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £246.73
6BF8 StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.89
Type: None
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 150 - 300
