StarTech.com PCI Express HD Video Capture Card 1080p30 – HDMI / DVI / VGA /  Component
Quicklinx: 822QWS00 Mfr#: PEXHDCAP
  • Windows 8 (32/64 bits)
Capture and convert an HDMI, DVI, VGA or Component Audio-Video source through a PCI Express slot. The PEXHDCAP PCI Express HD Video Capture Card enables you to capture high-definition video and audio from an HDMI, DVI or Component (1080p) source to your computer through a PCI Express expansion slot.
Support for full 1080p video input, as well as HDMI and RCA stereo audio makes this HD capture card the perfect solution for creating digital copies of your videos for editing and compiling. The added versatility of 3 different video inputs (HDMI, DVI, Component), plus the ability to capture VGA input using the included DVI to VGA adapter, or DisplayPort using an active adapter, gives you the freedom to connect a multitude of audio-video devices to your computer, quickly and easily.
This PCI Express capture card supports NTSC and PAL systems, and comes complete with an easy to use video capture software suite, allowing you to record video or take still screenshots and save them to your PC.
StarTech.com PCI Express HD Video Capture Card 1080p - video capture adapter - PCIe
Video capture adapter
Interface Type
PCIe
1 cm x 11 cm x 9.6 cm
300 g
Video Input
DVI-Analog/Digital, component video input, HDMI
Analogue Video Format
NTSC, PAL, PAL-M, PAL 60
Analogue video Signal
Component video
Digital Video Format
MPEG-4, H.264
Digital Video Capture Resolution
1280 x 720, 1280 x 960, 1024 x 768, 1280 x 1024, 800 x 600, 1080 x 720, 1920 x 1080, 1440 x 900
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Interface Type
PCIe
1 cm
11 cm
9.6 cm
300 g
Video
Interface Type
Component video
MPEG-4, H.264
2 x audio - RCA , 1 x display / video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x display / video - HDMI input - 19 pin HDMI Type A
Compatible Slots
1 x PCI Express x1
1 x DVI-VGA adapter
FCC, RoHS
System Requirements Details
Core 2 Quad - 2.66 GHz - RAM 512 MB
70 °C
822Q StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
