StarTech.com PCI Express 6 pin to 8 pin Power Adapter Cable
Quicklinx: 6BBMWS00 Mfr#: PCIEX68ADAP
Length: 15.5cm
Type: Power
£8.58 ex VAT
£10.29 inc VAT
Connect a standard 6-pin PCI Express power connection on the Power Supply to 8-pin ATI and NVidia video cards. The PCIEX68ADAP PCI Express 6 pin to 8 pin power adapter cable lets you connect a standard 6-pin PCI Express power connection provided by the computer power supply to ATI and NVidia video cards that require an 8 pin power connection.
A cost-effective solution, the PCIe 6 pin to 8 pin power adapter eliminates the expense of upgrading a computer power supply for the sake of compatibility with a newer video card.
  • Versatile connector options
    This power adapter cable features a 6 pin PCI Express power connector on one end and an 8 pin PCI Express power connector on the other, allowing for flexible connectivity options within a wide range of systems.
  • Environmentally compliant
    The cable meets RoHS and WEEE standards, ensuring compliance with environmental regulations, making it a responsible choice for eco-conscious users.
StarTech.com PCI Express 6 pin to 8 pin Power Adapter Cable - power adapter - 6 pin PCIe power to 8 pin PCIe power - 15.5 cm
Power adapter
Length
15.5 cm
Connector
6 pin PCI Express power - female
Connector (Second End)
8 pin PCI Express power - male
Yellow
P/N: ATX2POWER430, ATX2POWER530
Power adapter
Length
15.5 cm
Yellow
14 g
Connector
RoHS, WEEE
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
1.7 cm
Shipping Weight
19 g
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Length: 15.5cm
Type: Power
