StarTech.com PCI Express (PCIe) Gigabit Ethernet Multimode SC Fiber Network Card Adapter NIC - 550m
Quicklinx: 9Q9XWS00 Mfr#: PEX1000MMSC2
£122.45 ex VAT
£146.94 inc VAT
Connect a PCI Express-based desktop or rackmount PC directly to a Gigabit multimode SC fiber optic network. The PEX1000MMSC2 PCIe Gigabit Fiber Network Card lets you connect a desktop PC directly to a fiber optic network, by adding a multimode SC fiber port to your computer or server through an available PCI Express slot.
Perfect for integrating into new or existing fiber infrastructure over great distances, this card delivers full Gigabit bandwidth to your computer up to 550 meters away from your network source, using multimode 50/125 micron duplex SC fiber cable. Plus, for a wider spectrum of compatibility, this versatile card offers fiber integration with a computer up to 220 meters away when deployed to network frameworks consisting of multimode 62.5/125 micron cabling.
With fiber connectivity, your network is not susceptible to electronic interference, which can be problematic with standard RJ45 copper networks, making this fiber card ideal for secure network setups.
Plus, the card is equipped with a standard profile bracket and includes a low-profile/half-height bracket, making it easy to install in small form-factor computers or 1U server and rackmount applications.
  • Efficient performance
    With a data transfer rate of 1 Gbps, this network adapter ensures fast data transmission and effective network communication.
  • Robust compatibility
    This network card is compatible with both Mac and Unix operating systems, providing flexibility for various users.
  • Stable operation
    Designed for wired connectivity, this card maintains stable connections and supports various environmental conditions.
  • Reliable standards compliance
    Compliant with FCC and RoHS standards, this product adheres to regulatory requirements for safety and environmental responsibility.
  • User-friendly installation
    The PCI Express x1 interface allows for simple installation into existing systems, making it accessible for a wide range of users.
StarTech.com PCI Express Gigabit Ethernet Multimode SC Fiber Network Card - network adapter - PCIe - 1000Base-FX
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0
Ports
1000Base-FX
1.9 cm x 11.8 cm x 11.8 cm
70 g
Cabling Type
Ethernet 1000Base-FX
Fibre Channel
Data Transfer Rate
1 Gbps
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.5 - 10.9, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Hyper-V Server, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
Plug-in card
PCI Express x1
PCIe 1.0
Ports
1000Base-FX
Wired
Cabling Type
Fibre Channel
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Full duplex capability, 48KB packet buffer
1 x 1000Base-FX - SC multi-mode - x 2
Low-profile bracket
FCC, RoHS
3.2 Watt
Software Included
Drivers & Utilities
1.9 cm
11.8 cm
11.8 cm
70 g
45 °C
5 - 95% (non-condensing)
9Q9X StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £142.63
9Q9X StarTech.com PCI Express (PCIe) Gigabit Ethernet Multimode SC Fiber Network Card Adapter NIC - 550m In Stock £122.45
9Q9X StarTech.com 1m Fiber Patch Cable SC - SC In Stock £12.53
9Q9X StarTech.com 2m Fiber Patch Cable SC - SC In Stock £14.62
Type: Network Socket
