Connect a PCI Express-based desktop or rackmount PC directly to a Gigabit multimode SC fiber optic network. The PEX1000MMSC2 PCIe Gigabit Fiber Network Card lets you connect a desktop PC directly to a fiber optic network, by adding a multimode SC fiber port to your computer or server through an available PCI Express slot.
Perfect for integrating into new or existing fiber infrastructure over great distances, this card delivers full Gigabit bandwidth to your computer up to 550 meters away from your network source, using multimode 50/125 micron duplex SC fiber cable. Plus, for a wider spectrum of compatibility, this versatile card offers fiber integration with a computer up to 220 meters away when deployed to network frameworks consisting of multimode 62.5/125 micron cabling.
With fiber connectivity, your network is not susceptible to electronic interference, which can be problematic with standard RJ45 copper networks, making this fiber card ideal for secure network setups.
Plus, the card is equipped with a standard profile bracket and includes a low-profile/half-height bracket, making it easy to install in small form-factor computers or 1U server and rackmount applications.
Efficient performance
With a data transfer rate of 1 Gbps, this network adapter ensures fast data transmission and effective network communication. -
Robust compatibility
This network card is compatible with both Mac and Unix operating systems, providing flexibility for various users. -
Stable operation
Designed for wired connectivity, this card maintains stable connections and supports various environmental conditions. -
Reliable standards compliance
Compliant with FCC and RoHS standards, this product adheres to regulatory requirements for safety and environmental responsibility. -
User-friendly installation
The PCI Express x1 interface allows for simple installation into existing systems, making it accessible for a wide range of users.
- StarTech.com PCI Express Gigabit Ethernet Multimode SC Fiber Network Card - network adapter - PCIe - 1000Base-FX
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0
- Ports
- 1000Base-FX
- 1.9 cm x 11.8 cm x 11.8 cm
- 70 g
- Cabling Type
- Ethernet 1000Base-FX
- Data Link Protocol
- Fibre Channel
- Data Transfer Rate
- 1 Gbps
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.5 - 10.9, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Hyper-V Server, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x1
- PCIe 1.0
- Ports
- 1000Base-FX
- Connectivity Technology
- Wired
- Cabling Type
- Fibre Channel
- 1 Gbps
- Status Indicators
- Link/activity
- Full duplex capability, 48KB packet buffer
- 1 x 1000Base-FX - SC multi-mode - x 2
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- 3.2 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 1.9 cm
- 11.8 cm
- 11.8 cm
- 70 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £142.63 |
StarTech.com PCI Express (PCIe) Gigabit Ethernet Multimode SC Fiber Network Card Adapter NIC - 550m | In Stock | £122.45 |
StarTech.com 1m Fiber Patch Cable SC - SC | In Stock | £12.53 |
StarTech.com 2m Fiber Patch Cable SC - SC | In Stock | £14.62 |
