StarTech.com PC Wall Mount Bracket/Holder
Quicklinx: HDGCWS00 Mfr#: 2NS-CPU-WALL-MOUNT
Accessory Type: Wall Mount
31 In Stock
£57.85 ex VAT
£69.42 inc VAT
Professional PC Wall Mount Bracket is designed to meet the needs of IT professionals seeking a space-saving and convenient solution for their workstation setups. The supported desktop towers widths are between 1.9 to 7.8 inches (50 to 200 mm). This heavy-duty wall mount system is constructed of a 0.09in (2.5mm) thick powder-coated SPCC steel sheets, ensuring durability and strength. With a weight capacity of up to 39.6lbs (18kg), it provides a secure mount for desktop computers. Experience effortless installation with the keyhole mounting to speed up deployment.
  • Space-Saving Open Design
    Optimize your workspace by freeing up valuable desk or floor space. The computer wall mount system enables convenient concrete/wood stud wall mounting of a computer chassis. Alternatively, you can mount the computer to the side of a desk, enabling additional installation location options. Enjoy unobstructed access to drive bays, peripheral ports, and wiring with the open design of the PC holder.
  • Toolless Adjustment
    Quickly adjust the width of the PC wall mount bracket using the knobs. Included spacers protect the chassis and ensure a snug fit. The spacers allow different CPU sizes ranging from 1.9 to 7.8 inches (50 to 200 mm) up to Small Form Factor (SFF) computers.
StarTech.com PC Wall Mount Bracket, For Desktop Computers Up To 40lb, Toolless Width Adjustment 1.9-7.8in (50-200mm), Heavy-Duty Steel, CPU Tower/Case Shelf/Holder, Includes Mounting Hardware and Spacers (2NS-CPU-WALL-MOUNT) - desktop to wall/monitor mounting bracket (horizontal)
Desktop to wall/monitor mounting bracket (horizontal)
Package Content
Sliding bracket, 2 plastic spacers, 8 rubber self-adhesive spacers, 2 wall mounting screws, 2 concrete wall anchors, 2 hand knobs, 4 rubber self-adhesive pads, 2 rubber self-adhesive strips
Product Material
Plastic, rubber, steel
22 cm x 23.9 cm x 18.6 cm
2.6 kg
Open frame, tool-less adjustments
5-year warranty
Product Material
Package Content
22 cm
23.9 cm
18.6 cm
2.6 kg
25 cm x 19.5 cm x 15.5 cm / 6.6 kg
Finish
Powder coat
Weight Limit
18 kg
Limited warranty: - 5 years
HDGC StarTech.com 25ft. Hook-and-Loop Cable Tie In Stock £4.36
HDGC StarTech.com 25ft. Hook and Loop Roll - Blue - Reusable In Stock £4.27
HDGC StarTech.com Hook and Loop Cable Ties 50pk In Stock £6.62
