Professional PC Wall Mount Bracket is designed to meet the needs of IT professionals seeking a space-saving and convenient solution for their workstation setups. The supported desktop towers widths are between 1.9 to 7.8 inches (50 to 200 mm). This heavy-duty wall mount system is constructed of a 0.09in (2.5mm) thick powder-coated SPCC steel sheets, ensuring durability and strength. With a weight capacity of up to 39.6lbs (18kg), it provides a secure mount for desktop computers. Experience effortless installation with the keyhole mounting to speed up deployment.
Space-Saving Open Design
Optimize your workspace by freeing up valuable desk or floor space. The computer wall mount system enables convenient concrete/wood stud wall mounting of a computer chassis. Alternatively, you can mount the computer to the side of a desk, enabling additional installation location options. Enjoy unobstructed access to drive bays, peripheral ports, and wiring with the open design of the PC holder. -
Toolless Adjustment
Quickly adjust the width of the PC wall mount bracket using the knobs. Included spacers protect the chassis and ensure a snug fit. The spacers allow different CPU sizes ranging from 1.9 to 7.8 inches (50 to 200 mm) up to Small Form Factor (SFF) computers.
- StarTech.com PC Wall Mount Bracket, For Desktop Computers Up To 40lb, Toolless Width Adjustment 1.9-7.8in (50-200mm), Heavy-Duty Steel, CPU Tower/Case Shelf/Holder, Includes Mounting Hardware and Spacers (2NS-CPU-WALL-MOUNT) - desktop to wall/monitor mounting bracket (horizontal)
- Product Type
- Desktop to wall/monitor mounting bracket (horizontal)
- Package Content
- Sliding bracket, 2 plastic spacers, 8 rubber self-adhesive spacers, 2 wall mounting screws, 2 concrete wall anchors, 2 hand knobs, 4 rubber self-adhesive pads, 2 rubber self-adhesive strips
- Black
- Product Material
- Plastic, rubber, steel
- 22 cm x 23.9 cm x 18.6 cm
- 2.6 kg
- Open frame, tool-less adjustments
- 5-year warranty
- Product Type
- Product Material
- Package Content
- 22 cm
- 23.9 cm
- 18.6 cm
- 2.6 kg
- Shipping Dimensions (WxDxH) / Weight
- 25 cm x 19.5 cm x 15.5 cm / 6.6 kg
- Black
- Finish
- Powder coat
- Weight Limit
- 18 kg
- Limited warranty: - 5 years
StarTech.com 25ft. Hook-and-Loop Cable Tie | In Stock | £4.83 |
StarTech.com Hook and Loop Cable Ties 50pk | In Stock | £7.83 |
