The PLUS-T-ST is a Palo Alto Networks PAN-SFP-PLUS-T compatible copper transceiver module that has been designed, programmed and tested to work with Palo Alto Networks brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 100/1000/10GBase-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Palo Alto Networks PAN-SFP-PLUS-T Compatible SFP+ Module, 10GBASE-T, SFP+ to RJ45 Cat6/Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, 10Gbps SFP+ Module Transceiver - Lifetime Warranty (PLUS-T-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-TX, 1000Base-T, 10GBase-T
- Data Transfer Rate
- 10 Gbps
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 30 m
- OEM Manufacturer Equivalent Part Number
- Palo Alto Networks PAN-SFP-PLUS-T
- 6.8 cm x 1.37 cm x 1.38 cm
- 15 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GbE
- 10 Gbps
- 30 m
- Full duplex mode
- 1 x Ethernet 10GBase-T - RJ-45 female
- MTBF
- 510,469,759 hours
- FCC, MSA
- 6.8 cm
- 1.37 cm
- 1.38 cm
- 15 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
