StarTech.com Nylon Cable Tie Gun/Tool
Quicklinx: J4LLWS00 Mfr#: N10MM-CABLE-TIE-GUN
£23.65 ex VAT
£28.38 inc VAT
The portable, pocket-sized zip tie gun quickly installs nylon cable ties, tensioning and cutting off excess nylon from the cable tie in one motion, making wire bundling quicker and more consistent. The handle and trigger squeeze mechanism tightens and flush cuts the cable tie, leaving no sharp edges. Additionally, the tension dial offers the ability to set the bundle's tightness before the cable tie end is cut off. This TAA-compliant cable tensioner tool works with any length of nylon cable tie wrap and supports widths from 0.094inches (2.4mm) to 0.189inches (4.8mm), and thicknesses up to 0.063inches (1.6mm). Constructed with high-strength S45C steel for stress-handling parts like the cutting mechanism, and aluminum alloy for lightweight, corrosion-resistant components such as the handle and body, it ensures long-lasting durability.
  • Easy to Use
    The squeeze-handle and trigger mechanism tightens and flush cuts the cable tie, leaving no sharp edges. Additionally, the tension dial lets you set the bundle's tightness before the cable tie end is cut off.
  • Nylon Zip Tie Compatible
    This TAA-compliant cable tensioner tool works with nylon cable tie wraps of any length, supporting widths from 0.094inches (2.4mm) to 0.189inches (4.8mm), and thicknesses up to 0.063inches (1.6mm).
  • Quality Construction
StarTech.com Nylon Cable Tie Gun, Zip Tie Tightener/Install Tool, TAA - cable tie installation tool - TAA Compliant
Cable tie installation tool
12.7 cm x 15.6 cm x 2 cm
253 g
Product Material
Steel, aluminium
Black & red
TAA Compliant
Product Material
Steel, aluminium
12.7 cm
15.6 cm
2 cm
253 g
Enclosure Colour
Black & red
Tension dial, for cable ties width 2.4 - 4.8 mm, for cable ties thickness up to 1.6 mm
TAA Compliant
Shipping Width
17 cm
Shipping Depth
14 cm
Shipping Height
3 cm
Shipping Weight
400 g
50 °C
30 - 70% RH
