StarTech.com NVMe to 2.5/3.5 SATA Cloner
Quicklinx: J4LMWS00 Mfr#: N2-M2-SSD-DUPLICATOR
10 In Stock
£50.60 ex VAT
£60.72 inc VAT
The StarTech.com M.2 NVMe to 2.5/3.5" SATA Drive Duplicator offers efficient data duplication capabilities. Designed to support both M.2 2242/2260/2280 and 2.5" / 3.5" form factors, this device features a robust design with a passive airflow system to ensure optimal performance. With a duplication speed of 27 GB per minute, it allows for quick transfers, making the process of backing up or cloning drives efficient. Equipped with essential features such as TRIM management and SMART management, this duplicator is ideal for maintaining the health of drives. Hot-swappable functionality adds an extra layer of convenience, enabling users to swap drives without hassles.
  • Efficient duplication speed
    The duplicator delivers a duplication speed of 27 GB per minute, allowing for quick data transfers and backups.
  • Broad compatibility
    Designed to accommodate M.2 2242/2260/2280 and 2.5" / 3.5" SATA drives, this device provides support for different storage formats.
  • Smart management features
    Incorporating TRIM and SMART management, the device ensures that drives maintain performance and data integrity.
  • Convenient hot-swappable functionality
    Hot-swappable capability allows users to easily change drives without shutting down the duplicator, improving workflow efficiency.
  • Robust design
    The ABS housing and passive airflow design contribute to the durability and reliability of the unit during operation.
StarTech.com M.2 NVMe to 2.5/3.5" SATA Drive Duplicator, Dual Bay Cloner - solid state / hard drive duplicator - TAA Compliant
Solid state / hard drive duplicator
2 (max)
Supported Drives
SATA-600 / PCI Express (NVMe)
Duplication Speed
27 GBpm
North America, Japan, United Kingdom, Europe, Australia, New Zealand
Built-in Devices
Status LED
Storage Controller
SATA/NVMe (SATA-600 / NVMe)
Hard Drive
No HDD TRIM management, SMART management
AC 100-240 V
TAA Compliant
14 cm x 10 cm x 5.5 cm
292 g
Duplication Speed
27 GBpm
Enclosure Colour
Chassis
Built-in Devices
Status LED
Supported Devices / Modules Qty
2
Supported Drives
CPU
1 x JMicron JMS581D
Storage Controller
SATA/NVMe (USB-C 3.2 Gen 2)
Interface Type
SATA-600 / NVMe
Data Transfer Rate
10 GBps
Max Storage Devices Qty
2
Hard Drive
No HDD
Expansion Bays
1 (total) / 1 (free) x internal - M.2 2242/2260/2280 , 1 (total) / 1 (free) x internal - 2.5" / 3.5" shared
1 x SATA 6Gb/s (replication) - 22 pin Serial ATA , 1 x SATA 6Gb/s (replication) - 22 pin Serial ATA , 1 x USB 3.2 Gen 2 (1 rear) - 24 pin USB-C
Passive airflow design, bi-directional, 4Kn drive compatible, UASP support, sector by sector duplication mode, hot-swappable, ABS housing
1 x USB-C cable - 1 m
RoHS, WEEE
TAA Compliant
2 x rubber m.2 standoff
External power adapter
AC 100-240 V
0.1 Watt
14 cm
10 cm
5.5 cm
292 g
Shipping Width
24.9 cm
Shipping Depth
11.8 cm
Shipping Height
6.5 cm
Shipping Weight
600 g
45 °C
10 - 85% RH
