The Slim Lock Noble Wedge Slot Compatible, 6.6 ft Locking Cable from StarTech.com provides effective security for your notebook. Crafted from steel, this security cable lock ensures durability, making it a reliable choice for safeguarding your device. Featuring anti-theft protection and cut-resistant design, it helps prevent theft while offering ease of use with a combination lock method. Its 360° rotation allows for flexibility in positioning, making it convenient to secure your device in different settings.
Robust security features
This security cable lock includes anti-theft protection and cut-resistant features, making it a dependable choice for securing your notebook against theft. -
Durable steel construction
Made from high-quality steel, this locking cable is designed to withstand wear and tear, ensuring long-lasting use. -
Versatile locking mechanism
Equipped with a noble wedge lock type, this cable offers a combination lock method for increased security. -
Flexible placement options
The 360° rotation feature allows users to position the locking cable comfortably around their devices, enhancing usability in various environments.
- StarTech.com Slim Lock Noble Wedge Slot Compatible, 6.6ft Locking Cable - security cable lock
- Product Type
- Security cable lock
- Package Content
- Hook-and-Loop fastening strap
- Product Material
- Steel
- 15 cm 2.2 cm
- Length
- 2 m
- 105 g
- Anti-theft protection, 360° rotation, cut-resistant
- 2-year warranty
- Product Type
- Product Material
- Steel
- Package Content
- 15 cm
- 2.2 cm
- Length
- 2 m
- 105 g
- Shipping Dimensions (WxDxH) / Weight
- 2 cm x 5.3 cm x 1.6 cm
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- Noble wedge
- Lock Method
- Combination
- TAA Compliant
- Limited warranty: - 2 years
