The StarTech.com Slim Lock Noble Wedge Slot Compatible, 6.6 ft Locking Cable is a reliable security solution designed to protect notebooks from theft. Made from cut-resistant steel, this security cable lock features a 360° rotating head for flexible positioning, making it suitable for securing your device in public spaces or at work. The package includes two keys for easy locking and unlocking, along with a hook-and-loop fastening strap for neat storage. Specifically intended for notebooks, this lock ensures a perfect fit for devices with a wedge lock slot, providing users with peace of mind. Whether you're working at a cafe, in an office, or at school, this TAA-compliant lock is a dependable choice for keeping your notebook safe.
Enhanced security
The Slim Lock Noble Wedge Slot Compatible with a 6.6 ft locking cable offers a reliable solution to keep your notebook secure. The cut-resistant steel cable and 360° head rotation provide both strength and flexibility, ensuring your device remains where you left it. -
Easy to use
This security cable lock comes with two keys for easy access, alongside a hook-and-loop fastening strap for tidy storage when not in use. Its key lock method is straightforward, making it a hassle-free addition to your device's security measures. -
Designed for compatibility
Intended specifically for notebooks, this lock fits perfectly with devices equipped with a wedge lock slot. Its design ensures a snug and secure fit, offering peace of mind for notebook users.
- StarTech.com Slim Lock Noble Wedge Slot Compatible, 6.6ft Locking Cable - security cable lock - anti-theft
- Product Type
- Security cable lock - anti-theft
- Package Content
- Hook-and-Loop fastening strap, 2 x keys
- Product Material
- Steel
- 15 cm 2.2 cm
- Length
- 2 m
- 115 g
- Cut-resistant, 360° head rotation
- 2-year warranty
- Product Type
- Product Material
- Steel
- Package Content
- 15 cm
- 2.2 cm
- Length
- 2 m
- 115 g
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- Wedge
- Lock Method
- Key
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Noble Wedge Cable Lock, 5ft
