StarTech.com No-Stud TV Wall Mount - Low Profile VESA TV Mount 80"
Quicklinx: GBTGWS00 Mfr#: FPWHANGER
No-Stud TV Wall Mount - Slim Design with Tilt - For 37" to 80" Displays
This No-Stud TV Wall Mount enables you to easily and securely mount your display from 37" up to 80" to walls without the need to align the bracket with wall studs. Its steel frame supports displays up to 110lb / 50kg in weight and provides the ability to tilt your display to ensure your application and the ideal viewing angle are aligned.
Easy and Flexible Installation
The studless design of this Universal TV Wall Mount makes it easy for you to mount your TV to a drywall or plaster wall in any boardroom, office, or classroom setup. Simply choose the best mounting location and secure the mounting bracket into the wall (with included nails); no need to drill or look for wall studs. The included Automatic Spring Lock lets you conveniently mount and secure your TV in place.
Low Profile Slim Design
This Low Profile TV Wall Mount is perfect for applications like digital signage, where space and aesthetics are important. With a 1.2" profile from the wall, this Wall Mount TV Hanger provides a professional and clean look.
Tilt your Display
The Hanging TV Wall Mount lets you angle your TV towards your audience. The included wall-mounted spacers give you a choice to change the tilting angle (0°/ -5°) for a comfortable viewing experience.
The FPWHANGER is backed by a StarTech.com 5-year warranty and free lifetime technical support.
  • Easy and Flexible Installation
  • Low Profile Slim Design
StarTech.com No-Stud TV Wall Mount, Low Profile Heavy Duty VESA TV Wall Mount for up to 80 inch Display (110lb/50kg), Universal Television Wall Mount, Studless Tilting Flat Screen Mount - No Drill TV Mount mounting kit - for TV - black
Mounting kit - wall-mountable
7 cm x 13.3 cm x 3.1 cm
Tilt
-5° to 0°
2.4 kg
Recommended Use
TV
Recommended Display Size
37"-80"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
Max Load Weight
50 kg
Material
Steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x concrete anchors, 4 x M8x50 screws, 4 x mounting screws
5-year warranty
7 cm
13.3 cm
3.1 cm
2.4 kg
Material
Steel
Package Content
AV Furniture
Mounting kit
Recommended Use
TV
Placing / Mounting
Wall-mountable
37"-80"
Tilt
-5° to 0°
Max Load Weight
50 kg
Dimensions & Weight Details
76.9 cm x 20 cm x 4.5 cm / 2.6 kg
Limited warranty - 5 years
GBTG StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £3.02
GBTG StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
GBTG StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
