This portable Rotary Cable Stripper quickly and easily removes insulation from a variety of cables, making it an essential tool for network, coaxial, and multi-conductor cable preparation. This cable stripping tool features an easy-to-use design that enables effortless removal of cable jackets and insulation. With its 360-degree rotation, it ensures precise control, reducing hand strain during repetitive tasks. The tool fits cables with an outer diameter ranging from 3.5mm (0.13in) to 7.5mm (0.29in), making it ideal for various types of cables including UTP, FTP, STP, coaxial, and multi-conductor cables. Designed for use with a diverse range of cable types, this Network Cable Stripper features specific slots for both round and flat cables. It helps streamline your workflow by efficiently preparing coaxial, network, and audio cables for installation, making it an ideal tool for any professional or DIY project. This Cable Stripping and Cutting Tool allows you to adjust the clamping depth using a Phillips head screw to accommodate different cable thicknesses. This ensures precise insulation removal without damaging internal conductors. The built-in cutting slot enables you to neatly trim cable lengths, eliminating the need for additional cutting tools.
Easy-To-Use
This cable stripping tool features an easy-to-use design that enables effortless removal of cable jackets and insulation. With its 360-degree rotation, it ensures precise control, reducing hand strain during repetitive tasks. The tool fits cables with an outer diameter ranging from 3.5mm (0.13in) to 7.5mm (0.29in), making it ideal for various types of cables including UTP, FTP, STP, coaxial, and multi-conductor cables. -
Versatile Compatibility for Various Cables
Designed for use with a diverse range of cable types, this Network Cable Stripper features specific slots for both round and flat cables. It helps streamline your workflow by efficiently preparing coaxial, network, and audio cables for installation, making it an ideal tool for any professional or DIY project. -
Adjustable Depth & Integrated Cutter
- StarTech.com Network Cable Stripper and Cutter, Wire Stripping Tool - cable cutter/stripper tool
- Product Type
- Cable cutter/stripper tool
- 4.5 cm x 11 cm x 1.5 cm
- 45 g
- Product Material
- ABS plastic
- Grey
- 2-year warranty
- Product Type
- Product Material
- ABS plastic
- 4.5 cm
- 11 cm
- 1.5 cm
- 45 g
- Enclosure Colour
- Grey
- Adjustable clamp, cutter
- Shipping Width
- 12.8 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 49 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 30 - 70%
StarTech.com Network Cable Stripper/Cutter
